ᐅ KALLAX back panel chipped – is it normal to have flying wood chips?
Created on: 26 Jun 2021 08:13
PogirenHello everyone,
I recently assembled a KALLAX shelf from Ikea and noticed that the back panel is slightly damaged at one corner, apparently because small wood splinters chipped off during shipping or assembly. What puzzles me a bit is that it’s not just minor cosmetic damage – quite a few small wood chips have since spread around the area, sometimes even several pieces or splinters on the floor at the same time.
My question to you is: Is this normal for KALLAX shelves? That is, for back panels to get slightly damaged during assembly or transport, and for wood splinters to scatter around? Or is this more of a problem with the material quality or workmanship?
I want to make sure I don’t have any assembly defects or ended up with a poor-quality piece. I definitely want to avoid that, especially as I plan to use the shelf close to living areas.
Does anyone know this issue? What’s your experience? And how can I best prevent the back panel from breaking off further or producing more splinters?
Thanks for your advice!
Hello Pogiren,
Small chips on the back panel of KALLAX shelves are actually quite common, especially when the back panel is made of thin particleboard and needs to be hammered in or set upright. The back panel is relatively thin and not solid wood, which makes it fragile.
Wood chips flying off can happen when hammering in the back panel, which is not a big deal, but if there are many chips or larger pieces, it’s generally best to be cautious, as it could affect the stability.
An important question is whether the back panel was properly aligned and fully secured, as incorrect installation can put extra stress on one corner.
It can help to smooth the edges with fine sandpaper during assembly to remove splinters and prevent further damage. If the damage is larger, the back panel can usually be replaced easily or repaired with a thin wood glue.
Also, chip damage often occurs during transport, since packaging is sometimes not ideal for these thin parts.
Hope this helps you for now!
Hello Pogiren,
I had exactly the same problem with my KALLAX a few months ago. The back panel seemed too thin to me and actually cracked at one corner when inserting it, which then caused the wood splinters.
Unfortunately, this is typical for the cheap, thin particleboard panels that Ikea uses. They are not very sturdy and can splinter with sharp edges or too much pressure. That’s why it’s very important to attach the back panel carefully and evenly.
What helped me was to lightly sand the edges of the back panel beforehand to round them a bit – this prevents sharp spots where the material is more likely to splinter.
Also, next time I made sure to lay the back panel flat on the floor and then slide or tap it in with as even pressure as possible.
If you are unsure, you could also try to repair the parts a little with wood glue and appropriate wood filler before installation, but this is usually done for larger damages.
In general, small splinters are not a big issue if they are few, but of course, you should clean the surrounding area well if there are fine wood splinters.
Hello Pogiren,
I would like to explain in more detail the construction and material properties of the KALLAX back panel to help you better understand the situation.
KALLAX shelves typically use MDF or particleboard back panels, which are quite thin to keep the overall weight low and costs down. These panels are not as strong as solid wood but are comparable to particleboard, which can chip under pressure or sharp edges.
Chipping usually occurs at the corners or edges because these areas experience the most stress from nail or screw installation and from fitting into the groove channels.
Your observation that the back panel leaves small wood splinters could indicate that the material was either already stressed or handled unevenly during assembly (for example, hammering too hard or squeezing it too tightly into the grooves).
The way the back panel is fixed in place is also crucial: it is usually attached with small nails that can cause splinters if installed with too much force.
If you want, you could try to describe more precisely (or at least observe yourself) how you fixed the back panel: Did you hammer it in? Did you have difficulty getting it to fit exactly? Proper fit is very important here.
This way you can assess whether the issue is due to assembly errors or if the material just reacts this way. If the damage is minor, loose splinters can be sanded off gently with fine sandpaper, followed by applying wood glue and refixing the back panel.
I hope this helps you. A good approach is to insert the back panel not forcefully, but evenly and carefully. If the fit is not right, it might be worth considering an exchange if still possible.
Ethan schrieb:
The "flying" of wood chips can happen when driving in the back panel, that's not a big dealI completely agree! I’ve assembled KALLAX units several times myself, and yes, you do get small chips when putting it together. But it has never really affected the assembly.
The key is to place the back panel carefully and use a rubber mallet (not a hard hammer!) to tap in the nails or clips. Usually, that prevents much from happening. Then the whole unit will hold together very securely.
I’d also recommend covering the workspace well—this makes it easy to clean up small splinters and find them quickly.
So, I wouldn’t worry too much; this is normal and not a sign of poor quality.
