ᐅ KALLAX back panel warped repeatedly due to prolonged moisture exposure – possible solutions?
Created on: 13 Mar 2024 09:42
lafar34Hello everyone,
I noticed that the back panel of my IKEA KALLAX shelf is warped in several places. After a close inspection, I suspect this was caused by mold moisture, probably from dampness that accumulated behind the shelf. What disappoints me especially is that the shelf is not even old – barely two years.
My specific question is: What options are there to permanently repair or replace the warped back panel without having to dispose of the entire shelf? Are there perhaps special back panels that offer better protection against moisture, or methods that reliably prevent dampness?
I look forward to your experiences and suggestions.
The issue of warped backing panels caused by dampness in KALLAX units is unfortunately well known. IKEA uses thin MDF boards for the back panels, which are not very moisture-resistant.
Repairs are usually only a temporary solution since the wood fiber material swells when exposed to moisture. A more effective approach is to replace the backing panel with a more water-resistant hardboard (HDF) or even plywood.
As a protective measure, it is recommended to place a thin plastic sheet or a thicker insulating board behind the shelf before installation to prevent moisture from entering. Additionally, drafts and indoor climate should be controlled to avoid recurring dampness.
Oh, I know that feeling! After a small flood, the back of my shelf developed similar waves near the wall! 🙂
I simply replaced it with a new HDF board and sealed the edges with silicone – it’s holding up great now!
And hey, another tip: don’t place the shelf directly against a cold, damp wall. Always leave some air space. This helps the material last much longer. It made a big difference for me! 🙂
To prevent permanent damage, the wood material should never be exposed to moisture again.
A sustainable solution is to replace the back panel with a water-resistant material, such as HDF or plywood with appropriate sealing.
Additionally, I recommend sealing the back panel with a strong moisture barrier on the inside of the wall or using silicone seals. This prevents recurring dampness regardless of the room’s humidity.
Using a dehumidifier can further reduce the humidity in the room.
Dopoki schrieb:
It is more effective to replace the back wall, for example with a more water-resistant hardboard (HDF) or even plywood.That may generally be true, but the question here is: how durable are these alternative materials in everyday use?
Also, the focus is almost exclusively on moisture coming from the wall. Shouldn’t it also be checked whether indoor air or other factors, such as condensation, contribute to the problem?
One should not only concentrate on a repair but also on identifying the causes – otherwise, the same problem may occur again.
