ᐅ Is it possible to use the Kallax completely without a back panel?
Created on: 25 Feb 2024 19:07
ELPHILO
ELPHILO
25 Feb 2024 19:07
I am currently considering a piece of furniture for my home and am thinking about the Kallax shelving unit from IKEA. Specifically, I am wondering: is it possible to use the Kallax without the back panel without compromising stability or the overall appearance? My main concern is whether the shelf will still be load-bearing enough and if it can be safely placed free-standing in the room, or if the back panel is essential. I would appreciate any advice or experiences regarding assembly, stability, and visual impact.
BARSAN
25 Feb 2024 19:23
The Kallax is less stable without a back panel than with one. For free-standing placement, the back panel is almost always necessary. Otherwise, it may become wobbly.
TRADI
25 Feb 2024 19:46
Regarding the back panel of the Kallax, I can say that the back panel indeed contributes significantly to the stability because it makes the frame torsion-resistant. Without a back panel, the shelving unit should either be secured to the wall or only used in situations with low loads.
Sometimes people use the shelving without a back panel because they want a more visually appealing back side, but in that case, I strongly recommend adding additional reinforcements or ensuring that no heavy loads are placed on the shelves. You might also want to know how to make it more stable if you leave out the back panel?
ELPHILO
25 Feb 2024 19:52
TRADI schrieb:
The back panel actually contributes significantly to the stability because it makes the frame torsion-resistant.
Thank you, that meets my expectations. I am also interested in whether it is possible to install some kind of alternative to replace the back panel, such as reinforced braces or metal plates. Because the appearance and free access from two sides would actually be desirable.
SONLIS
25 Feb 2024 20:08
The idea of replacing the back panel with other elements is fundamentally reasonable. The most suitable option is usually metal angle brackets installed diagonally, which reinforce the Kallax at the corners and thus improve its shear stiffness. Alternatively, reinforcement with battens in specific areas can also work, but these need to be cut precisely and fixed securely to be effective. It is always important that the shelf is braced in a way that prevents wobbling or warping, especially under heavier loads.
Dustin
25 Feb 2024 20:19
Stable without a back panel? No. Just use something else instead of a back panel, for example metal brackets, then it works. Freestanding without a back panel will be difficult.
