ᐅ KALLAX back panel chipped – is it normal to have flying wood chips?
Created on: 26 Jun 2021 08:13
Pogiren
I recently assembled a KALLAX shelf from Ikea and noticed that the back panel is slightly damaged at one corner, apparently because small wood splinters chipped off during shipping or assembly. What puzzles me a bit is that it’s not just minor cosmetic damage – quite a few small wood chips have since spread around the area, sometimes even several pieces or splinters on the floor at the same time.
My question to you is: Is this normal for KALLAX shelves? That is, for back panels to get slightly damaged during assembly or transport, and for wood splinters to scatter around? Or is this more of a problem with the material quality or workmanship?
I want to make sure I don’t have any assembly defects or ended up with a poor-quality piece. I definitely want to avoid that, especially as I plan to use the shelf close to living areas.
Does anyone know this issue? What’s your experience? And how can I best prevent the back panel from breaking off further or producing more splinters?
Thanks for your advice!
I would like to raise a somewhat critical point:
This raises the question of whether the manufacturer might have cut costs on the material; the KALLAX series is known for a good price-performance ratio, but often at the expense of the materials used.
Furthermore, I would ask if there might be inherent weak points in the back panels caused by the manufacturing processes, making the material especially prone to chipping.
It would also be interesting to know whether quality control at Ikea failed in this case, or if the panels were damaged during shipping.
Personally, for such a critical part as the back panel, I would prefer a more robust solution, since the back panel not only contributes to the visual appeal but also plays a significant role in stability. If it loses chips, stability is compromised.
Therefore, I would be very interested in experience regarding material thickness, manufacturing processes, and any possible improvements.
LENNAU schrieb:
The back panel seemed too thin to me and actually broke at one corner during installation
pilous schrieb:
That raises the question of whether the manufacturer might have cut corners on the materialsIt’s actually quite clear: when you produce cheaply, you save on materials. Ikea has become more of a discount retailer than a premium brand. – And that’s exactly why you shouldn’t have excessive quality expectations for such inexpensive furniture; especially KALLAX is known for affordable, functional mass-produced items.
A few wood chips falling off isn’t a big deal at the end of the day; if you want flawless wood, you buy solid wood or much higher-quality pieces.
And honestly, if a few dust particles bother you, you should probably avoid Ikea.
The real issue is people who complain despite knowing what they’re buying.
Ikea delivers inexpensive shelves, not design masterpieces.
nanidra schrieb:
Ikea delivers affordable shelves, not design treasuresThat is basically true, but I would still emphasize that Ikea is making significant efforts to offer higher-quality products using sustainable materials and improved material usage.
The back panel in the KALLAX is a cost factor, so it is thin, but that does not contradict its functional purpose. Most issues usually arise more from rough handling during assembly than from the material itself.
Therefore, one should always consider the ways the product is handled and assembled. If someone uses a hammer that is too heavy and strikes too hard, even the best material can be damaged.
Thus, it is a combination of material quality and handling that can lead to damage.
Thanks for the previous answers, they have already helped me a lot.
I tapped the back panel lightly with a small hammer, but not too hard, rather gently. Still, the splinters appeared. So it seems to be a sensitive material.
That's exactly what I noticed as well. The back panel is slightly too wide at the top edge for the shelf – I had to press it a bit and then it fit into the groove. It’s quite possible that the clamped areas were damaged as a result.
I will try that, sounds reasonable. It should look cleaner afterwards and reduce the risk of further chipping.
What about exchanging the back panel in general, if it deteriorates? Has anyone done that and was it straightforward?
What do you think about additional reinforcement of the back panel? Like gluing on a thin board from the outside or something similar?
bapar schrieb:
Fit accuracy plays a big role here
LENNAU schrieb:
rounding off slightly with fine sandpaper
Pogiren schrieb:
I noticed the same thing: the back panel is slightly too wide at the top edge for the shelf—I had to press it in a bit for it to fit into the groove.This definitely sounds like stress from the assembly process is causing damage to the material. When the board gets wedged in due to deformation, stress points form, which is where the material tends to chip off.
Regarding replacement: Ikea usually doesn’t sell back panels separately, but you can request a spare part. Most are quite accommodating, especially if the damage occurred during shipping.
Alternatively, you could have a thin OSB or MDF board cut to the right size and use it as a back panel. This option is often even more stable and durable.
Reinforcing the back with a thin wood or plastic sheet attached from the outside is possible, but it doesn’t look quite as neat. However, if you plan to place the shelf against a wall or secure the back panel in place, that could be a practical solution.
I recommend carefully removing the back panel, sanding it lightly, sealing any small cracks with wood glue if necessary, and only then reattaching it.
If you have any questions about removing the panel, I’m happy to help.
Great approaches here, thanks!
I would also recommend fixing the back panel only once all four sides are properly aligned. This helps avoid tension at the corners. The order in which you drive the nails can also help: fix the middle first, then work outward.
Additionally, small damages can be covered with color-matched adhesive sheets if the splinters bother you visually.
Good luck!
Good luck!
