ᐅ My KALLAX shelf warped after being exposed to sunlight – what can I do now?
Created on: 14 Nov 2023 08:27
CurtpraGood morning everyone,
I have a rather specific problem with my KALLAX shelf from IKEA. After being left in the sun on the balcony for a long time, some of the shelves have become warped, which leads me to ask: How can I smooth out or at least repair these warped shelves without having to replace the entire unit?
The shelves are made of laminate-coated fiberboard, and the warping is probably caused by moisture and heat exposure. I am particularly interested in whether heat or moisture worsens the problem and if there are any proven DIY methods to restore the material’s shape.
I would appreciate any tips – how have you dealt with a similar situation or what would you recommend?
Hello Curtpra,
First of all, very good and detailed description of your problem – that really helps with finding a solution.
The warping of the shelves in the KALLAX unit often happens because the fiberboard has absorbed moisture and then deformed. Laminate offers some protection but is not completely waterproof.
My advice in several steps:
1. Remove moisture: Place the shelves in a dry, warm place (but not in direct sunlight) so they can dry slowly and potentially shrink back a little.
2. Apply weight: Put heavy, flat objects on the shelves to help stabilize their shape while they dry.
3. Use heat: If you have a steam iron, you can carefully (always with a cloth) slightly moisten the laminate and then iron it. This often helps fiberboard to regain its shape. However, always be cautious not to damage the laminate.
4. As a last resort, replace: If none of this works, I would recommend getting new shelves (often sold separately at IKEA).
I hope this helps you for now! A combination of drying, weighted pressure, and careful heat application is usually the best DIY approach.
This effect is typical for wood-based materials that absorb moisture. It is important to dry them slowly and under controlled conditions. Rapid heating or excessive heat can cause permanent damage to the fiber structure.
I recommend a combination of shaded air drying and applying weight. In cases of severe warping, replacing the shelves may be advisable, as the material loses stability afterward.
Hello Curtpra,
A brief tutorial on repairing warped KALLAX shelves:
1. Understand the cause: The board swells due to moisture penetrating the wood fibers inside – laminate only provides limited protection on the surface.
2. Procedure:
- Remove the boards from the shelf and lay them flat on a dry surface.
- Ideally, press a cloth onto the surface and then apply a little steam ironing over the cloth to relax the fibers.
- Alternatively or additionally, place several heavy flat objects on top (e.g., books, metal sheets).
3. After treatment: Let the boards dry in the air for a while and avoid storing them again in an environment that is too warm or too humid.
4. Long term, try to minimize sources of moisture near the shelving if possible.
5. Replacement: Replacement shelves for KALLAX are available online or at IKEA. They are often reasonably priced.
Summary:
Dry slowly, weigh down, and if necessary, carefully apply steam or heat treatment. This significantly extends the lifespan of the shelves.
2. Procedure:
Summary:
