ᐅ Installing Siemens HB634GBS1 and Siemens BE634RGS1 units in IKEA Metod kitchen cabinets
Created on: 21 Dec 2016 22:18
gabor1984G
gabor198421 Dec 2016 22:18Hello,
I’m new here. I’m currently planning an IKEA kitchen but want to install Siemens appliances.
For the oven, I plan to use the Siemens HB634GBS1, which should fit into the IKEA oven cabinets in terms of width and height, right?
The external dimensions are 59.5cm x 59.5cm (23.4 inches x 23.4 inches), so it should align flush at the front with the rest.
I might also install a Siemens BE634RGS1 microwave above it. It is 38.2cm (15 inches) high, so there would be a 1.8cm (0.7 inches) gap up to the next drawer front.
Does anyone have a solution for this? Even if I put the microwave in the wall cabinet where the Framtid microwave usually fits, there would still be the 1.8cm (0.7 inches) gap above.
I’m looking forward to your suggestions.
IKEA-Experte22 Dec 2016 10:52Hello,
the oven fits.
You have to be creative with the microwave. You can cut a narrow strip from a 10cm (5 inches) drawer front, build something with a square tube, take an overlapping door 20cm (8 inches) larger and shorten it so that it reaches the microwave (if the decor allows), or come up with something else.
the oven fits.
IKEA-Freund22 Dec 2016 11:04Since the appliance has a narrow stainless steel strip at the bottom of the front, you could have a brushed stainless steel panel custom-cut and mount it over the strip.
Regards,
IKEA-Freund
Regards,
IKEA-Freund
gabor198422 Dec 2016 22:04Thanks first of all for the tips.
I also want to install a Siemens dishwasher with a Vario hinge. According to Siemens, the SX736x03ME model should fit. Can I simply attach an 80cm (31.5 inches) front panel and place the kickboard below it, and that will be fine?
