are there special door hinges for corner wall cabinets? The closing angle is about 135° there, not 90° like with cabinets mounted parallel to the wall. Because of that, the door has (almost) no inherent "closing force."
Oh, and a second question regarding the hinges: for my 60cm (24 inch) wide wall cabinet, I have the problem that the hinge tension is no longer strong enough to close the door properly. Is there a way to fix this? Also, this 60cm (24 inch) door hangs slightly crooked despite correct screw adjustment. I suspect the door might simply be too heavy for the hinges (it’s a tall wall cabinet, about 90cm (35 inch) high…).
Maverick18542 Feb 2011 09:10So, you have already sorted everything out with IKEA? Or not?
