ᐅ Are there any tips for replacing IKEA Brimnes hinges?
Created on: 17 Nov 2020 09:12
Tekutra
Hello everyone, I have a specific question: Are there any useful tips or best practices for replacing the hinges on IKEA Brimnes furniture?
The hinges on my Brimnes dresser are starting to show signs of wear, and I want to replace them either with identical original parts or suitable alternatives. It is important for me to know the best way to carry out the replacement, which tools are needed, whether there are standard sizes, and if the new hinges need to be properly adjusted so that the doors close perfectly again.
Since IKEA often uses proprietary components, I am also curious if the hinges can be replaced with other models from a hardware store, or if a direct replacement through IKEA is the only viable option.
I look forward to your tips and experiences!
noge58
18 Nov 2020 08:42
Hey, I recently had the exact same problem! 😊 My recommendation is to order the original hinges directly from IKEA or reputable spare parts suppliers. I tried alternatives from the hardware store – they didn’t fit well and required constant fiddling!
Also: When replacing them, I removed all the hinges completely before installing the new ones. The adjustment screws are really handy, and now the doors swing like new again!
One last tip: Be careful not to tighten the screws too much, as this can damage the mechanism.
Palenar
18 Nov 2020 09:03
noge58 schrieb:
One last tip: be careful not to overtighten the screws
This is important – overtightening can strip the threads in chipboard, especially with thinner materials like those commonly used in flat-pack furniture.
I recommend the following procedure when installing hinges:
- Use the original hinges for full compatibility
- Screw them in lightly, then hang the door and align it
- Adjust the door using the adjustment screws until it sits flush and without play
- Only fully tighten at the end with moderate torque
Also, make sure the hinges are free of chips and dust to ensure smooth movement.
gekira
19 Nov 2020 10:21
Summary and Structured Notes:
- IKEA Brimnes hinges are usually cup hinges with integrated soft-close functionality
- Replacement parts should ideally be original, as dimensions and fittings are proprietary
- Step by step: remove the door, loosen the hinge, install and snap in the new hinge, rehang the door
- Small adjustment screws on the hinge allow corrections of alignment in three dimensions
- Avoid overtightening the screws to prevent thread damage, as particle boards are affected
- If the hinge shows significant mechanical defects, replacement is essential
- Tools: appropriate Phillips screwdriver, possibly a small hex key or flat blade to release the clips
No compromises on the replacement hinge, otherwise the door will not function properly.
Taubi
19 Nov 2020 11:03
Hinges at IKEA usually differ only slightly, and various models often fit interchangeably. Soft-close is not necessarily required; simple hinges can also be used as replacements.
You need to check the mounting and drill holes, and then it generally fits.
Taylorsi45
20 Nov 2020 14:09
If hinges are not available: Pay attention to the drill hole diameter (about 35 mm (1.4 inches)) and screw position to find alternative products.
Small tip: Avoid soft plastic washers, as screws tend to rotate easily with them.
kibutar
21 Nov 2020 09:38
gekira schrieb:
In case of significant mechanical damage to the hinge, replacement is essential
I fully agree with that.
One more thought: When you unscrew the hinge, you can check the drill holes for cracks, especially in older furniture. If the particle board around the hole is damaged, you can improve strength by inserting a wooden glue plug. This is important because otherwise new screws will not hold securely.
If you notice that the holes are completely torn out, repair sleeves available on the market can help, or simply a small wooden dowel glued in place with wood glue.
This extends the hinge’s lifespan and prevents the door from losing stability again.
