ᐅ What is the best way to plan the IKEA PLATSA system?
Created on: 25 Apr 2016 08:17
nikolay
Good morning everyone, I am facing the task of planning the IKEA Platsa system for my living room. I especially want to focus on clever use of space and flexible modules that can adapt to changing needs. I have already tried several versions, but I lack a structured approach to make the planning efficient and well thought out. Therefore, my question is: How do you best plan the Platsa system? Do you use specific tools, have tips for measuring and assembling, or recommendations for accessories and modifications? What points should be particularly considered from experience to avoid problems later, such as incorrect dimensions or missing connectors? I look forward to your detailed and practical advice!
MAVERICKKA
26 Apr 2016 08:27
LEOPAU schrieb:
Common mistakes often include: - Inaccurate room measurements (overlooking windows, heating units, door openings) - Ignoring the module depth during planning (resulting in doors or drawers not fitting properly)
I want to emphasize this, especially since measurements for recesses and projections are often not straightforward. Moreover, the importance of load distribution in the modules is frequently underestimated. Platsa can be weight-restricted depending on its design – some users hang items that are too heavy, which can cause problems.
Sinzar
26 Apr 2016 08:45
On-site adjustments are good, especially for doors – sometimes the measurements on paper do not correspond to how they appear in the actual space.
Teonon
26 Apr 2016 09:05
And don’t forget: If you can test individual modules, also pay attention to how the doors and drawers work together – some combinations fit better or worse!
Pome60
26 Apr 2016 10:15
Don’t get discouraged! If you plan well here, you’ll get an amazing system that can grow and change anytime! Tip: Many people like drawers, but also try open shelves— they look great and keep everything easily accessible!
nikolay
27 Apr 2016 12:22
Thank you for all the helpful tips so far. Could someone explain how the drawer fronts and panels work? I have seen that there are different sizes and heights—how do you combine them correctly with the Plästa modules? Is there a general rule of thumb or a typical setup that fits? Also, I would prefer not to have any visible screws on the outside; is this possible with the system?
SINTAR
27 Apr 2016 12:40
Drawer fronts come in various heights and widths, so you should match them precisely to the module dimensions. A good rule of thumb is to always choose modules and fronts that fit each other; otherwise, they won’t align properly. Screws are usually not visible because IKEA uses an internal connector system.
