ᐅ KALLAX doors become loose after several years – should the screws be tightened?
Created on: 16 Feb 2018 18:03
balzdeo
I have an IKEA KALLAX shelving unit for which I installed the doors a few years ago. Now, after about 5 years of heavy use, I've noticed that some of the doors are quite loose and no longer sit firmly. The doors are attached using the supplied hinges and screws, which are screwed into the pre-drilled holes.
My specific question is: Should I simply tighten the existing screws to restore the doors’ stability, or are other measures necessary to prevent the door attachments from becoming loose over time? Has anyone experienced similar issues and can offer advice on the best way to fix this?
Thanks in advance!
Thanks in advance!
It's brilliant that you can fix the doors securely again with such simple measures! 🙂 I had similar issues with KALLAX doors, and after tightening the screws, everything was perfectly stable again.
Tip: Take your time and carefully check all the screws. I sometimes completely forgot that they need to be retightened. After that, the doors feel like new!
GLALEO schrieb:
after tightening, everything was perfectly stable again.Great, thanks for the confirmation!
Fitigu schrieb:
A more durable approach would be to use metal threaded insertsHow difficult would that be for someone with average DIY skills? I don't have a workshop, but with some patience and the right tools, I can manage most tasks. Would this method make the construction more secure in the long run?
KarTristan20 Feb 2018 09:23balzdeo schrieb:
How difficult would this be for someone with average DIY skills?Metal threaded inserts are usually not a problem if you have the right drilling tools and prepare the holes properly. However, they are generally a bit more involved than simply repairing with wood glue and small wooden pieces.
My advice: If the piece of furniture is otherwise intact and the effort isn’t too high, threaded inserts can provide real improvements in stability. You just need a suitable countersink or drill bit, pliers or an insertion tool, and some patience to position them accurately. Otherwise, tightening the screws or re-drilling and reinforcing the holes with wood glue and dowels is usually sufficient.
