ᐅ What is the best way to plan the IKEA PLATSA system?
Created on: 25 Apr 2016 08:17
nikolay
Good morning everyone, I am facing the task of planning the IKEA Platsa system for my living room. I especially want to focus on clever use of space and flexible modules that can adapt to changing needs. I have already tried several versions, but I lack a structured approach to make the planning efficient and well thought out. Therefore, my question is: How do you best plan the Platsa system? Do you use specific tools, have tips for measuring and assembling, or recommendations for accessories and modifications? What points should be particularly considered from experience to avoid problems later, such as incorrect dimensions or missing connectors? I look forward to your detailed and practical advice!
nikolay
25 Apr 2016 10:35
LEOPAU schrieb:
4. Planning with the IKEA planner: Create a design using the online planner, but double-check the measurements on paper at the same time.
Thank you, LEOPAU, your detailed step-by-step guide is very helpful. However, I’m curious about how you manage stability, especially when combining multiple modules. Can any type of connector be used, or are there limitations? Also, I’d like to know how you use the back panels – I have different versions, but no clear recommendation.
SINTAR
25 Apr 2016 10:47
Connectors should always be used according to the specific module type; otherwise, the system becomes unstable. Back panels provide additional stability, especially for larger configurations. It is best to use all the back panels offered by IKEA.
baelku
25 Apr 2016 11:02
Back panels are very important; otherwise, the entire structure may wobble. Even if they are not visible, they make the storage space more secure and prevent pressure or tipping movements.
Teonon
25 Apr 2016 11:25
Back panels are definitely a must! I would also recommend keeping the modules to just a few basic sizes to make assembly and future rearranging easier. And: Have fun planning – it’s really enjoyable once you get into it!
nikolay
26 Apr 2016 07:42
Good morning everyone, I wanted to follow up: Are there any common mistakes you often encounter in practice when selecting the Platsa modules? For example, I have read that some people struggle with the dimensions and wall thickness. How can such pitfalls be avoided? I am also interested in whether it makes sense to order individual modules in advance and measure them on site before purchasing the entire set.
LEOPAU
26 Apr 2016 08:01
nikolay schrieb:
Are there any common mistakes you often encounter in practice when selecting PLATSA modules?
That is a very good question! Common mistakes often include: - Inaccurate room measurements (overlooking windows, radiators, door openings) - Ignoring the depth of the module during planning (resulting in doors or drawers not fitting properly) - Incorrect selection of connectors, often missing a specific fastener - Neglecting the load capacity of the modules – planning to store items that are too heavy. Regarding "ordering individual modules in advance": It can be helpful to first assemble a sample module at home to experience the quality, workmanship, and dimensions firsthand. This also helps to decide, for example, if the depth and height are suitable. This often prevents problems later on.
