ᐅ Are there back panels for the Kallax shelves that provide a complete seal against insects?
Created on: 25 Dec 2023 09:17
Gauflo
Good morning everyone!
I am currently planning to assemble my Kallax shelf in the dining room and am wondering if there are back panels for the Kallax that actually seal well enough to prevent insects or small crawling creatures from getting through. I’m especially interested in whether there are materials or models that not only serve as a visual back panel but also provide a true barrier against insects.
Do you have any experience with special back panels that can be retrofitted, or perhaps any DIY tips on how to properly seal the back yourself? It is important to me that the shelf is completely closed at the back without having to apply complicated sealing later on. I would really appreciate any specific recommendations!
Gauflo
25 Dec 2023 12:27
Thanks for your inputs so far!
@Jeanbar says that the usual hardboard panels don’t provide proper sealing, and I agree. The gaps are really the main issue, and a clean sealing of the edges is probably essential.
Could you say more about these "rigid foam boards" that @Timofa mentioned? Are they really sturdy enough? I want the back panel to be stable and not easily damaged, especially with regular dusting or if something presses against it.
And @JORDON, how exactly did you attach the PVC sheet? Just clipped into the groove or also glued? Is there a trick to prevent it from coming loose again when loading items?
GALENKU
25 Dec 2023 12:55
PVC or plywood remain the best options for a waterproof back panel. Rigid foam boards are water-resistant but very soft and easily damaged. For a long-lasting solution, I would choose plywood and seal it carefully.
fredle
25 Dec 2023 13:33
Brief summary:
1. The original backing boards made of fiberboard (about 3 mm (0.1 inches) thick) are not really suitable for keeping insects out. They are mainly used for stabilization or dust protection.
2. For a proper barrier, I recommend thin plywood sheets (4–6 mm (0.15–0.24 inches)) that you cut very precisely.
3. It is important to seal the edges with silicone or a permanently elastic acrylic sealant to prevent any gaps.
4. For attachment: screws or small nails, not Velcro or adhesive tapes. This ensures the panel stays securely in place.
5. PVC panels are an alternative, especially if moisture resistance is needed for the backing. However, they are more expensive and not always easy to work with.
6. Rigid foam boards like extruded polystyrene can be used for sealing but are mechanically less stable.
If you want the full process, I can gladly provide a step-by-step guide.
theo63
25 Dec 2023 14:12
I would like to raise a critical question:
Are there back panels that provide 100% insect-proof sealing? I believe such products only exist in laboratory-grade items with extremely tight sealing. Other wooden or plastic panels mainly serve as barriers against larger gaps.
I would rather recommend thoroughly inspecting the shelf itself for any leaks (especially joints and rear transitions) and systematically sealing these areas with appropriate sealing materials. The back panel alone is not a guarantee that insects won’t get through.
Gauflo
25 Dec 2023 14:41
theo63 schrieb:
I think something like that only exists for laboratory-grade products with extremely tight sealing.
That’s an important perspective, thank you. I understand that you probably can’t get a 100% guarantee, but the tighter, the better.
So I am looking for the most durable, airtight solution that is realistic for a typical household.
Thanks also to @fredle for the great overview! I would gladly accept a step-by-step guide, as long as it’s not too much trouble.
fredle
25 Dec 2023 15:03
Gladly, here is a brief guide:
1. Purchase a plywood sheet with a thickness of 4-6 mm (about 0.16-0.24 inches), slightly larger than the Kallax unit’s dimensions.
2. Cut the sheet precisely to size so that it fits snugly into the back.
3. Lightly sand the edges to improve adhesion of the sealing material.
4. Apply a permanently elastic sealant (silicone or acrylic) to the edges and the contact area with the back panel of the shelving unit.
5. Insert the sheet and secure it with small screws or thin nails.
6. If necessary, apply additional sealant to all gaps between the shelving unit and the wall.
7. Let everything dry thoroughly – that’s it.
This way, the back panel is sealed all around and should prevent insects from passing through.
