liClement29 Nov 2019 10:12Good morning everyone, I recently bought the Ikea Brimnes wardrobe and am currently assembling and adjusting it. I’ve noticed that the doors don’t close completely flush and the frame seems slightly warped. Unfortunately, the two adjustment screws on the door hinges are not very intuitive, so I wanted to ask which method works best for adjusting this wardrobe? Specifically: How can the Brimnes wardrobe be adjusted most effectively to ensure the doors close straight and flush, and that the entire piece feels stable? I look forward to any tips, tricks, or shared experiences regarding useful fine-tuning for this model and what to pay special attention to.
The Brimnes wardrobe actually has some special features when it comes to adjustment. First, you should install all the doors so you can properly assess the gaps between them. The hinges offer three adjustment options:
- Vertical adjustment by raising or lowering the door
- Horizontal adjustment to align the doors flush with each other
- Depth adjustment so the door does not protrude too far or sit too deep
My recommendation is to first loosen all the screws slightly, then adjust the height so the gap at the top and bottom is even. After that, correct the horizontal alignment, and finally the depth. Be sure to close the doors repeatedly and check throughout the process.
It is important not to overtighten the hinges during adjustment to avoid breaking the material. How uneven is your floor? This can also make the adjustment more difficult.
liClement29 Nov 2019 12:05Domau0 schrieb:
It is important not to overtighten the hinge when adjusting it too much in order to prevent material breakage.Thank you for the advice, I will definitely keep that in mind. Regarding your question, the floor is slightly uneven, but I have already placed small wooden wedges under the cabinet feet to compensate for this as much as possible.
For me, the depth adjustment is the least clear. Is there a specific adjustment screw that is commonly overlooked? Or a tip on how to most effectively tell when the depth is set correctly?
The depth adjustment on the Brimnes is made using the screw that pushes the hinge horizontally against the mounting plate. This is often the smallest screw on the hinge body. To adjust this correctly, you should first have the door aligned perfectly in height and lateral position.
Then, carefully turn the depth screw until the door is flush with the cabinet frame without binding. Tip: Check the gaps at several points to rule out distortions caused by uneven walls or floors.
Additionally, I recommend always closing the doors fully when adjusting the hinges so that they are set under load, preventing any future misalignment.
