I recently purchased an Ikea Brimnes wardrobe and would like to find out how much weight or what type of load this wardrobe can actually support.
I am particularly interested in how many kilograms each shelf can hold, whether there are differences between the various models (e.g., with or without doors, drawers), and what material limits should not be exceeded to avoid permanent damage.
Perhaps someone here has practical experience with loading this wardrobe or knows reliable data from tests?
My main concern is to use the wardrobe in a way that ensures stability and safety, not just theoretical maximum values.
Thank you in advance!
Hello!
I have a BRIMNES in my bedroom that I mainly use for clothes and a few books. Based on my experience and various forums, the shelves should hold around 15 kg (33 lbs) each, although you shouldn’t load all shelves evenly to their maximum capacity.
My recommendation is not to load it like a truck, otherwise the wood will eventually give way. The ideal way to load it is:
- Lightweight clothes
- Books or folders better arranged staggered rather than packed tightly
At home, I store my heavier items on the lower shelves, which also improves stability. Avoid placing heavy items on the top shelves, as it can easily tip over.
I’d say it’s better to load it moderately than risk the bottom shelf breaking out 😁
From a technical perspective, the Ikea BRIMNES is typically made of coated particleboard. In the product description, Ikea usually states that each shelf has a maximum load capacity of approximately 15 kg (33 lbs).
Depending on the model (with doors, drawers, or without), the load capacity may vary slightly, but the main limitation is the shelves themselves.
Recommendations:
- Maximum load per shelf: about 15 kg (33 lbs)
- The total weight should not exceed the load limits of the fasteners and the back panel
Proper assembly also plays a role in stability: brackets and fasteners must be installed accurately according to the instructions.
Recommendations:
It’s interesting that everyone seems to aim for 15 kg (33 lbs) per shelf – I would argue that this is a bit too conservative.
I have personally loaded my cabinet with considerably more – books and even electronic devices – and yes, after 2 years there are slight deformations, but nothing dramatic. You just need to know what you’re doing and not overload it as if it were a truck bed.
kieran schrieb:Sure, particleboard doesn’t sound like heavy-duty material, but who says the load can’t be partial or localized?
Haha, cool! Books as heavy loads? Sounds almost like we’re discussing an IKEA version of the Swiss Army knife here ?
Jokes aside, I actually find the 15 kg (33 lbs) rule quite practical for everyday use.
The important things are simply:
- don’t place too much weight on a single surface
- store the heavy items at the bottom (for center of gravity)
- and occasionally check the screws to make sure nothing is loose
I’ve filled mine with sports clothes, a few pairs of shoes, and my books so far without any issues.
