ᐅ What advice do you have for dealing with issues with Ikea Brimnes drawers?
Created on: 2 Mar 2018 08:12
Naumeo
I recently started having an issue with the drawers of my Ikea Brimnes wardrobe. Specifically, one of the lower drawers sticks when pulled out and doesn’t close properly anymore, which significantly limits its use. The drawer is correctly seated in the frame, and I have already checked for any obstructions or jams, but there aren’t any. I’m interested to know if anyone else has had similar experiences with the Brimnes drawers and what solutions or tips you would recommend for problems with the mechanism or similar malfunctions. A lasting solution would be especially important to me, as I use the drawer regularly and can’t keep readjusting it. Thanks in advance for your helpful responses!
TELAHAU
2 Mar 2018 13:47
One quick tip: Check if the drawer sides are installed slightly crooked. This often happens with Brimnes, especially if the pre-drilled holes are slightly misaligned.
If the sides are slightly off, it helps to push the drawer in and out while turning the screws to find the correct position. Even a small misalignment can affect the entire sliding mechanism.
BERONAR
3 Mar 2018 08:23
I always find it surprising how often Ikea products like Brimnes fail due to seemingly small details.
The problem with the drawers could be seen as a symptom of careless mass production, where even minor deviations can have serious consequences.
Perhaps it would be worth considering whether, instead of constantly trying to fix functional issues with low-cost parts, it might be better to invest directly in higher-quality furniture. Of course, this comes down to cost. Nevertheless, it is an interesting point of discussion whether Ikea makes too many compromises in quality in certain areas.
Naumeo
3 Mar 2018 09:45
[@BERONAR, post: e6h3s0, member: XXX]
I always find it surprising how often IKEA products like Brimnes fail due to seemingly small details.
The issue is that you really can't underestimate these small tolerances in furniture construction, especially for components like drawer slides, which require a precise fit. In the wooden furniture industry, measurements are often required to be accurate to the millimeter. IKEA seems to be a bit more tolerant in this regard, likely to make assembly easier and production cheaper.
However, I also see the value for money, especially with the Brimnes model, which can often be fixed with some care and fine adjustment. I think that's exactly why I'm looking for tips here to find affordable solutions without having to replace the entire piece of furniture.
blaix
3 Mar 2018 11:12
It is interesting that the topic of quality and manufacturing tolerances comes up right away here.
However, I would critically question whether the problem with the drawer really lies only with the furniture itself or possibly with the construction method or the environment (e.g., humidity, uneven floor).
Because:
- Wood or particle boards react to moisture by swelling, which can cause drawers to stick.
- A floor that is not completely level can deform the cabinet or cause slight misalignment.
It would therefore be advisable to check the installation location and also consider the room’s humidity. Perhaps there is a cause there that can be easily resolved.
Gino38
4 Mar 2018 07:55
Good point from blaix. I would like to add that with Brimnes, the screws on the back panel often don’t hold as firmly as you might expect. This can cause the frame to twist easily.
My advice: additionally support the back panel from the inside with thin wooden strips or improve the fastening by using stronger screws. This helps to make the cabinet more stable and reduces problems with the drawer runners.
Naumeo
4 Mar 2018 09:36
[@blaix, post: w8v6l50, member: XXX]
It’s interesting that the topic of quality and manufacturing tolerances comes up here right away.
I can confirm your points regarding moisture and the substrate. The cabinet is in a slightly more humid room, and the floor isn’t perfectly level, but I hadn’t expected that to affect the drawer movement so much.
I will check this first and, if necessary, use washers to compensate for the unevenness.
[@Gino38, post: w8v6l51, member: XXX]
Your tip about using wooden strips for stabilization also sounds very reasonable. Thanks! If that doesn’t help, I will try it and report back.
