Hello everyone, I am interested in the durability of the Ikea Brimnes cabinets, specifically: How long does a typical Ikea Brimnes cabinet usually last with normal use, for example in a bedroom or living room? I mainly want to know how sturdy the construction is over several years and whether material fatigue, stability issues, or other signs of wear commonly occur that should be considered beforehand. Perhaps some of you have personal experience with the product, such as how many years the cabinet lasted for you and the exact usage conditions. An assessment regarding the quality of the components, workmanship, and assembly would also be very helpful. Thank you in advance!
The term "durability" is quite vague. What does "typical" mean in this context? Usage varies, as does the quality of installation. I wonder if we should be discussing value and replaceability instead. Are there reliable figures or long-term experiences available? In my opinion, IKEA furniture is more of a consumer product with an intentionally limited lifespan.
To better assess the durability of the Ikea Brimnes wardrobe, here is a brief overview:
- Material: particleboard with a foil surface, susceptible to moisture
- Construction: screw and dowel connections, relatively simple design
- Common weak points: back panel, shelf supports, hinges
Experience shows that with proper assembly and a dry environment, 7 to 10 years is realistic. Stability may degrade with overloading or frequent disassembly.
My advice: regularly tighten screws and distribute weight evenly.
