ᐅ What weight can IKEA Brimnes shelves support?
Created on: 3 Jun 2018 07:43
dikeo
dikeo
3 Jun 2018 07:43
I am currently planning to get the IKEA Brimnes shelving unit and have a specific question: What is the maximum load capacity of the shelves in this model?
I have already read that the shelves are made of particleboard with a melamine coating, but I am mainly interested in how much weight I can roughly place on a single shelf without it sagging or becoming permanently damaged.
Since I intend to put both books and various decorative items on it, it would be helpful to get some practical experience, possibly depending on the width or depth of the shelves.
If anyone has been using and loading this shelving unit for some time, I would greatly appreciate an assessment or even some measurements.
Thank you in advance!
nofomu
3 Jun 2018 08:15
I have loaded Brimnes shelves with up to 15 kg (33 lbs) per board without any issues. I would not exceed 20 kg (44 lbs) to avoid bending.
Shawn38
3 Jun 2018 09:27
Hello dikeo,
The issue with IKEA furniture and its load capacity is often that the manufacturer’s specifications are only partially practical. For the Brimnes shelves, a load capacity of around 15 kg (33 lbs) is usually indicated, which is sufficient for books and decorative items.
What matters is how the load is distributed: If you spread many small objects evenly, the shelf can hold more weight. However, if you place heavier items in one spot, it may bend more quickly.
I would recommend not loading the shelves beyond their midpoint and ensuring an even distribution of weight. If you have very heavy books, it might be better to use multiple shelves or install additional support strips.
Tufu57
3 Jun 2018 10:03
The Brimnes shelves typically support up to 15 kilograms (33 pounds). If you plan to load more weight, add additional supports or use different shelving.
gaubla
3 Jun 2018 11:56
Regarding the precise load capacity of IKEA Brimnes shelves: The material used is particleboard with a melamine coating, as mentioned earlier. The manufacturer recommends a maximum load capacity of about 15 kilograms per shelf.
However, the mechanical load capacity depends on several factors:
- The span of the shelves (distance between support points)
- The type of load distribution (point load vs. distributed load)
- The thickness of the shelf (usually about 1.8 cm (0.7 inches) for Brimnes)
Tests with similar boards of this thickness show that bending can occur under loads exceeding 15 kg (33 lbs).
My advice: For heavy loads, such as large books, it is recommended to reinforce the shelves with additional vertical supports or to use smaller shelf sections to reduce the span. This helps prevent structural damage and extends the furniture’s lifespan.
dikeo
3 Jun 2018 13:22
Shawn38 schrieb:
The important factor is how the load is distributed: if you evenly spread many small items, the shelf can support more weight.
Thanks for the tip, I had suspected that. Could you also tell me if there are any differences in load capacity between the larger (125cm (49 inches) wide) and smaller (80cm (31 inches) wide) versions of the Brimnes shelves? Are the smaller shelves more stable because of the shorter span, or does the material degrade equally in both?
