ᐅ How can I securely and stably attach Ikea Brimnes shelves?
Created on: 23 Aug 2023 09:17
nar_po59
nar_po59
23 Aug 2023 09:17
Hello everyone, I need some advice on how to securely and stably fasten Ikea Brimnes shelves. I have the Brimnes shelving unit with adjustable shelves, but I’m unsure how to best secure the shelves so they don’t slip or wobble under medium loads. The dowels and shelf supports provided by Ikea seem a bit fragile to me. I’m wondering if there are better options or additions to achieve a significantly more stable fixing of the shelves that are also easy to implement. Are there any experiences, tips, or even recommended alternatives to the original fasteners? I’m not looking for a complete DIY solution, but a practical technical upgrade that remains compatible with the Ikea system. Thanks in advance!
roryvin
23 Aug 2023 09:35
The Brimnes shelves are normally supported by plastic dowels and metal pins, which is usually sufficient for light to medium loads. For greater stability, it is recommended to:
- Use metal shelf supports instead of plastic dowels. These provide better grip in the drilled holes.
- Check that the dowel holes are not worn out, as this can cause wobbling.
- If necessary, re-drill and reinforce with some wood glue.
It is also important not to place a very heavy load evenly on a single shelf in order to avoid stress concentration.
Jensson
23 Aug 2023 11:08
Here is a summary of the steps to securely fix the Brimnes shelves:
1. First, install the appropriate metal shelf supports if possible. These are sturdy and usually fit into the designated drill holes.
2. Before placing the shelves, carefully check the drill holes for any damage. If there are any splinters, smooth the edges with fine sandpaper.
3. If the drill holes are slightly too large, you can mix wood glue with fine sawdust and carefully apply it to improve the grip.
4. Gently place the shelves to avoid misaligning the supports and ensure a proper fit.
5. For extra stability, you may attach a thin angle bracket under the shelf if additional fastening is allowed.
An important tip: Uneven loading and frequent shifting of the shelves can cause loosening over time. Therefore, distribute weight evenly.
Tofra45
23 Aug 2023 11:45
- Use metal post bases
- Check holes for damage
- Possibly use glue/sawdust mixture
- Even load distribution
That’s all you need.
Lucien
23 Aug 2023 13:03
It is important to also pay attention to the frame construction of the Brimnes shelf unit. Since the shelves are simply placed on top, they tend to tip more easily if the side panels are not firmly connected. Therefore:
- Ensure precise adjustment of the frame and tighten all screws.
- Use shelf supports with a secure fitting; avoid cheap plastic options.
- For increased weight, consider additional angle brackets under the shelf, which should be installed discreetly to maintain the appearance.
This approach significantly improved stability in similar Ikea furniture without much effort.
nar_po59
23 Aug 2023 14:20
roryvin schrieb:
It is also important not to place a very heavy load evenly on a single shelf to avoid load peaks.
Could you explain this in more detail? I especially want to avoid shelves sagging over time or slipping out of their holders when I place, for example, books on them. What amount of weight per shelf is realistic without needing additional reinforcements?
