ᐅ Are there specific tools recommended for assembling Ikea Brimnes furniture?
Created on: 21 Sep 2022 08:17
NonbeHello everyone, I am planning to assemble an Ikea Brimnes piece of furniture soon, and I have a question: Are there any specific tools that are especially recommended for assembling Ikea Brimnes or that make the process significantly easier? I am familiar with the usual tools like screwdrivers and a hammer, but I wonder if Ikea provides any special tools or if certain aids really make sense to speed up or improve the safety of the assembly. I am particularly interested in experiences regarding whether using certain screwdriver bits, angles, or other tools has proven helpful. Thanks in advance for your tips and advice!
I can easily understand how frustrating it can be when you don’t have the right tools on hand during assembly.
In my experience, Ikea often includes the essential tools with Brimnes, such as an Allen key designed for specific screws. This is usually enough for basic assembly, but if you want to work more comfortably, it’s worth having a set of suitable bits for a cordless drill.
Sometimes I’ve had trouble screwing in the screws perfectly straight, where a right-angle adapter would have been helpful.
I know that such a small investment can be off-putting at first, but it really makes the process more enjoyable and saves a lot of stress.
cassandra21 Sep 2022 11:24In summary: Ikea Brimnes furniture typically comes with a simple Allen key. No special tools are officially required.
I recommend:
- A cordless drill with the appropriate Allen and Phillips bits
- A rubber mallet instead of a regular steel hammer to prevent damage
- An angle or ratchet attachment for hard-to-reach screws
These tools make assembly easier, help avoid damage to materials, and save time.
As far as I know, Ikea does not provide or recommend any special tools.
I recommend:
Here is a brief guide for assembling Ikea Brimnes, based on my previous experiences:
1. Tool selection:
- Ikea usually provides a small Allen key, which is sufficient for assembling the main connections.
- For faster work, a cordless drill with adjustable torque and Allen bits is recommended.
- Most connections require a 4mm Allen key.
2. Procedure:
- Initially, insert screws and connectors only loosely to allow for later adjustments.
- Fully tighten screws only at the end to avoid strain on the parts.
3. Caution regarding damage:
- Use a rubber mallet for wooden parts to prevent dents.
- Check screw holes before inserting screws to ensure nothing gets stuck.
Summary: There are no special Ikea tools required, but having good equipment as described makes the process much easier.
1. Tool selection:
2. Procedure:
I would like to add to the previous points:
When assembling Brimnes, precision is helpful, so a hex key (Allen key) or screwdriver with a good grip and the correct bit size is important. In my experience, a standard cordless drill is advantageous because it controls the torque well and does not apply too much force at once, which helps prevent damage to plastic joints or veneer wood.
Additionally, an angle attachment for the drill could make screwing in tight spaces easier.
However, there is no special tool that Ikea exclusively supplies or recommends. The standard assembly hardware is usually sufficient.
