ᐅ How can I add extra shelves to Ikea Metod cabinets?
Created on: 10 Jun 2022 08:13
tamarasau
I am currently considering how to add extra shelves to my Ikea Metod kitchen cabinets to make better use of the storage space. At the moment, I only have the standard shelves installed, but the spacing is too large for me, and I would like to create smaller compartments.
Does anyone have experience with the best way to retrofit shelves? Are special anchors or brackets required? Is it possible to use other materials for the shelves instead of the original Ikea parts? It is especially important to me that the shelves are stable and do not bend, as I have quite a bit of weight to store.
I look forward to your tips, experiences, or creative solutions!
FAVALERIE9
10 Jun 2022 12:18
I did it like this: I ordered original Ikea shelves, then drilled the holes at the desired distance using a Lego drill bit and additionally secured them with suitable metal brackets. It holds great and is easy to implement.
Kukar
10 Jun 2022 12:44
The best way to add extra shelves is by using the peg holes inside the cabinet. You will need dowels plus shelf supports from Ikea or standard 5mm (0.2 inch) shelf pins. This also allows you to use your own boards.
PEDRO40
10 Jun 2022 14:03
I understand well how important stability is to you. With my Metod cabinets, I also thought about it for a long time and then decided to use the original shelves – they are really strong enough. If you choose different shelves, make sure to test them thoroughly beforehand so you don’t have to worry about slight sagging.
If you need help with the installation, just ask; everyone here is happy to assist!
tamarasau
11 Jun 2022 07:56
Thanks first of all to everyone for the helpful feedback!
I have one more question: What about the depth of the shelves if I want to use my own MDF boards, for example? Ikea Metod cabinets have a depth of 60cm (24 inches), but will any board fit in there, or do I need a custom size?
I want to avoid the shelves being too short or too long, as that wouldn’t look good visually and could also affect the stability.
naujon
11 Jun 2022 08:44
That’s a very good question. Ikea Metod cabinets are generally 60 cm (24 inches) deep. The boards should be about 56 to 57 cm (22 to 22.5 inches) wide to allow enough clearance all around for installing the shelves without forcing them in, especially where there are drill holes for brackets and ventilation.
If you want precise measurements:
- Measure the inside width of the cabinet bottom from left to right where the shelf will rest.
- Subtract about 3 cm (1.2 inches) to allow space for the wall and some tolerance.
For MDF, I recommend a thickness of 16 to 18 mm (0.6 to 0.7 inches) for sufficient stability—the thicker, the better, but also more expensive and heavier.
Also, make sure to sand or seal the edges smoothly to prevent swelling from moisture.
This way you’ll get nicely fitting, durable shelves.
PEDRO40
11 Jun 2022 09:33
tamarasau schrieb:
I want to avoid the shelves being too short or too long, because that doesn't look good to me and can reduce stability.
I completely understand. When making your own cuts, keep in mind that the thickness of the cabinet sides can vary, which may affect the measurements. It’s best to use a spirit level and cut 1–2 mm (0.04–0.08 inches) smaller rather than too large.
This way, you prevent the shelves from being too tight or having to bear unnecessary pressure.
