ᐅ What is the safest way to secure IKEA Brimnes shelves?
Created on: 27 Aug 2018 18:23
Sesin
Sesin
27 Aug 2018 18:23
Hello everyone, I recently bought an IKEA Brimnes shelving unit and plan to secure the shelves in a way that is as stable and strong as possible. The included brackets are simple but a bit wobbly for my needs, especially when stacking heavy books or larger items on them. My question is: What methods or additional fasteners would you recommend to securely attach the shelves in the IKEA Brimnes shelving unit? I am open to tips on screws, wall plugs (anchors), connectors, or other practical solutions. Are there any tricks or modifications that go beyond the standard assembly instructions but work really well based on your experience? Thanks in advance for your input!
Franz
27 Aug 2018 19:07
Hello Sesin, I completely understand how important a secure fixing of the shelves is to you. I also had concerns for a long time because my shelves started to wobble after a while with the standard method. What really helped me was reinforcing them with small brackets on the side panels to relieve the load from the shelf supports. For this, I used small galvanized angle brackets from the hardware store and attached them with short screws into the side panels and the underside of the shelves. This provides noticeably more stability and also gives a reassuring feeling that the shelf won't easily bend or give way. Maybe this could be a viable solution for you too?
Johnathon
27 Aug 2018 19:46
Hello Sesin, I would like to approach your question systematically because the stability of shelves depends on various factors. First, you should know that the Brimnes series is designed according to the typical IKEA standard, which holds up under normal use but can give way under heavier loads and frequent stress. Here are my recommendations:
- First, check the load capacity of the shelves: manufacturer specifications usually state around 15-20 kilograms per shelf (33-44 pounds).
- Improve stability with additional corner braces, as Franz described, ideally galvanized metal brackets to prevent corrosion.
- When assembling, use high-quality nylon wall plugs or even metal expansion anchors instead of plastic plugs, especially if you can secure the shelf to the wall.
- If you want it extra sturdy, you can insert small metal rods or threaded rods through pre-drilled holes in the side panels and shelves and then screw them in. This creates continuous load transfer.
- It is also important to anchor the shelf to the wall, even if it appears stable and steady at first glance. With heavier loads, it might tip over or warp otherwise.
My follow-up question: What specific loads do you want to place on the shelves? Books, decorations, electronics? And how flexible are you regarding modifications? Many screws and reinforcements can make later disassembly more difficult.
Espen
27 Aug 2018 20:01
The shelves are most securely fastened when you reinforce the supplied brackets with additional small angle brackets and attach the shelving unit to the wall. This reduces wobbling and significantly increases load capacity.
NOAHSAU
27 Aug 2018 20:31
I believe the best approach is not to rely on the standard mounting – IKEA shelves are designed more for quick assembly rather than heavy-duty use. What’s the point of drilling and screwing through the wood excessively? If you’re going to use the shelves as heavy load bearers, they could be built entirely differently. My advice: get sturdy wooden battens, screw them under the shelves as additional supports, and secure them firmly to the sides. Although this is a modification and no longer original, it makes the construction much more durable. This way, you don’t have to worry about the inexpensive materials from IKEA.
Roberta
27 Aug 2018 20:43
I installed the shelves by simply fastening them to the side panels with stronger screws and additionally secured small metal brackets. This is sufficient for normal household loads. However, I would not recommend the shelving unit without wall anchors.
