ᐅ Are there specific screws designed for assembling the IKEA BRIMNES that fit better?
Created on: 25 Sep 2024 10:13
Waclawte68
Waclawte68
25 Sep 2024 10:13
Hello everyone, I am currently planning to assemble an IKEA Brimnes wardrobe and noticed while sorting the screws that some of the supplied screws do not fit well or tend to twist or get slightly damaged during assembly. Therefore, my question is: Are there any special screws or alternative materials for assembling the BRIMNES that are better sized, more durable, or specifically designed for this furniture series? I want to build the piece as stable and durable as possible without having weak points in the joints later on. Does anyone have experience with alternative screws for BRIMNES, for example in terms of metal quality, size, length, or thread thickness, that are particularly recommended for assembly? Many thanks for any tips or advice!
Dilen
25 Sep 2024 11:07
Hello Waclawte68, I find your question about screws for the BRIMNES wardrobe interesting and can provide a more detailed explanation. The issue with IKEA furniture is often that the supplied screws are generally suitable, but repeated assembly and disassembly or improper handling can cause problems.
It is important to note that IKEA furniture is usually designed for easy assembly using particleboard screws, which are cost-effective but often made from soft metal and do not always provide the most durable fastening.
For greater stability when assembling the BRIMNES, I would recommend using coarse-thread screws designed specifically for particleboard instead of the supplied screws. These screws often have a thicker diameter and a longer partial thread length, which significantly improves holding power in the simple particleboard. Additionally, using screws made of stainless steel or galvanized steel is worthwhile to prevent corrosion, especially if there might be moisture in the room.
It is also important during assembly to carefully screw in the fasteners with a suitable bit or screwdriver to avoid over-tightening or damaging the particleboard. If the hole is already slightly worn out, small wooden dowels can be used for reinforcement before inserting alternative screws.
If you like, it would be interesting to know whether the screws that came with your BRIMNES poorly fit during the initial assembly or if this issue occurred mainly during later disassembly and reassembly.
Kinbu
25 Sep 2024 11:29
Hello Waclawte68,
From my experience, the screws provided by IKEA are usually sufficient for the initial assembly. However, with the BRIMNES series, it can sometimes happen that the screws don’t grip optimally in the pre-drilled holes, especially if they are not inserted precisely or if the openings are slightly too large.
If the screws don’t fit well for you, you can alternatively buy chipboard screws of the same length and diameter at a hardware store. Please pay attention to the following points:
- Thread type: Coarse-thread screws are suitable for chipboard.
- Length: should roughly match the original screw to avoid problems when fastening.
- Material: Zinc-plated or stainless steel is recommended if moisture is a factor.
I suggest using the original screw as a template and then selecting a screw with the same measurements. It is also important not to tighten the screw too much to prevent the material from splitting.
I hope this helps!
koduga
25 Sep 2024 13:15
Hello Waclawte68,
I can fully understand how frustrating it can be when the screws don’t fit well during assembly or cause problems. Especially with furniture like BRIMNES, which you might want to assemble multiple times, it can leave you uncertain whether everything will remain stable.
Perhaps it helps to know that you don’t necessarily have to use the original screws if you have better alternatives. However, I recommend planning such changes carefully: Sometimes screws that are too thick or too long can be counterproductive with BRIMNES, since the furniture parts are quite thin.
One of my experiences is that the way you insert the screws matters a lot during assembly: Especially with particleboard and MDF panels, you shouldn’t screw in too quickly or use too much force.
It’s encouraging that other users here have had similar experiences and achieved better results with alternative screws. I would like to expand your question: What specific problems are you encountering with the screws? For example, are they too short, stripping out, or spinning freely? This can help to find a more targeted alternative solution.
Waclawte68
25 Sep 2024 14:02
Dilen schrieb:
If the hole is already a bit worn out, you can also use small wooden dowels for reinforcement before trying alternative screws.
Thanks for the tip, Dilen, I hadn’t considered that yet. I actually got the impression that especially in the rows of holes along the side panels, the screws fit a bit loosely—probably the holes are slightly worn out.
koduga schrieb:
What specific problems are you experiencing with the screws? Are they too short, stripping out, or spinning without gripping?
That’s a good description, koduga: Sometimes the screws spin while being driven in because the threads don’t properly engage with the material. It really feels like the hole is too large or the thread pitch is too fine for the particleboard.
The screws are actually long enough, but if the fit isn’t perfect, you lose the holding strength. That’s why I think specially threaded particleboard screws or screws with thicker heads might help here.
I’ll test whether wooden dowels provide reinforcement and am still looking for recommendations on suitable screw types for BRIMNES. Does anyone have more detailed technical advice?
Filippo
25 Sep 2024 15:18
Hello Waclawte68,
Here is a somewhat more technical approach regarding screws for BRIMNES and similar furniture:
IKEA furniture often uses screws designed specifically for particleboard, featuring a middle section and coarse threads to ensure better grip. However, with BRIMNES, it is common to notice that the holes are not always perfectly pre-drilled, which can cause some play.
For a secure connection, I would recommend:
- Screws with a thread profile specifically designed for particleboard (coarse thread or "Spax-type")
- A thread length at least twice as long as the thickness of the material being fastened
- Using wood glue or assembly adhesive in the dowel holes to improve the bond between the board and the screw
- If the holes are already worn out, reinforce them first by inserting wooden dowels or plastic anchors to strengthen the hole
Additionally, when assembling IKEA furniture, reducing the torque setting on your cordless drill can help. Using too much force can easily over-tighten screws and damage the material.
A good practice is to tighten screws moderately and avoid using a deep screwdriver bit or an overly powerful cordless drill.
Can you specify which areas the screws tend to perform poorly? Side panels, hinges, back panel?
