ᐅ What tools do I need to assemble IKEA Brimnes furniture?
Created on: 25 Dec 2015 10:37
Tepakar
Tepakar
25 Dec 2015 10:37
Hello everyone, I am currently planning to assemble some furniture from the IKEA Brimnes series and want to prepare well in advance. My question is: What tools are actually needed to properly and efficiently assemble the furniture from the Brimnes line? I have already read the IKEA assembly instructions, but they often only show symbols, so it is unclear whether the included tools are sufficient or if it is better to have some additional tools on hand. I am especially interested in tools that make the assembly easier or help avoid common pitfalls. I would be very grateful for a detailed list along with a brief explanation of why each tool is needed!
JAPLO
25 Dec 2015 10:52
The most important insight upfront: IKEA usually provides only a small Allen key, which is generally sufficient but not always the most convenient to use. For the Brimnes set, I recommend the following tools:
- A solid hex Allen key (usually 4 mm (5/32 inch))
- A cordless drill with an Allen bit to save effort and time
- A hammer for dowels and possible minor adjustments
- A small Phillips screwdriver in case screws without Allen heads are used
The cordless drill makes assembly much easier, as many screws in the Brimnes are quite tight. The included Allen key is often too short and awkward to handle. I would not use a large drill bit, as this could damage the wooden joint connector.
KAMERON
25 Dec 2015 11:14
For additional information: The Brimnes furniture construction is based on several connection systems, including minifix dowels, wooden dowels, and screw connections with Allen screws. The most important tools are therefore:
- Allen key (IKEA provides one, usually only a single size, so having a set is advantageous)
- Cordless drill with adjustable torque to avoid over-tightening screws
- Hammer for securing wooden dowels
- Flat screwdriver in case plastic clips are involved
It is important that the cordless drill is adjustable to prevent damage to the materials. Durable bits may also be recommended.
Fredlo
25 Dec 2015 11:40
Oh yes, assembling the Brimnes is really enjoyable when you have everything ready! 🙂 Besides good preparation, I would also recommend having a sturdy work surface and some time set aside. A really great tip from me: use a cordless drill! It saves a lot of time and frustration. The included Allen keys are tiny—I almost got a cramp in my hand using them. It’s also important to be gentle when tightening the screws, otherwise the furniture can become misaligned! So, just take it easy and most importantly, keep at it—the result is definitely worth it.
janeo
25 Dec 2015 12:05
JAPLO schrieb:
The cordless drill greatly simplifies the assembly, as many screws in the Brimnes fit quite tightly.
I would like to disagree, at least when it comes to using a cordless drill without adjustable torque settings. Too much torque can easily lead to overdriven screws, which not only damages the furniture but also reduces its stability.
Therefore, I would recommend paying close attention to choosing a screwdriver with adjustable torque. Even better: turning the screws by hand until resistance is felt, then tightening only slightly further.
It should also be understood that assembling the Brimnes does not require advanced craftsmanship, but some care is necessary during assembly to avoid damaging the material.
George
25 Dec 2015 12:24
For assembling Brimnes, you mainly need:
- Allen key (included by IKEA)
- Hammer
- Cordless drill with an Allen bit
With these tools, you should be well prepared.
