Hello everyone, I recently bought some IKEA Brimnes furniture, mainly cabinets with doors, and I’ve noticed that the doors don’t close properly. They stick in some places, are not flush, or hang slightly crooked. I’m interested in how to correctly adjust the doors of the IKEA Brimnes furniture so they close cleanly and evenly. Are there specific adjustment screws or mechanisms one should be aware of? If so, what is the best way to adjust the doors? I have already looked through the assembly instructions, but the adjustments are only briefly mentioned there. Thanks for your tips!
nileru schrieb:
I’m interested in how to properly adjust the doors of the IKEA Brimnes furniture so that they close cleanly and evenly.This is really important, as a poorly adjusted door not only looks unappealing but can also affect durability. Most IKEA models, including Brimnes, have adjustment screws on the hinges that allow you to align the door horizontally or vertically. However, you should check if Brimnes allows adjustment in both directions. Sometimes the adjustment range is limited, which can be challenging with slightly warped doors. Have you checked if the doors have screws on the inside of the hinges marked with small indicators?
Thanks for the tips so far! I’ve taken a close look at the hinges. There are indeed three screws per hinge, but I’m having trouble understanding the exact function of each screw. The top screw seems to adjust the door’s depth, but I’m unsure about the horizontal and vertical adjustments. Is there a specific order or method to systematically align the door correctly? Maybe someone here has already tried this step by step?
For precise adjustment of the IKEA Brimnes doors, I recommend the following procedure:
- First, adjust the vertical alignment: Loosen the screws for vertical adjustment slightly, position the door so that it is level with the carcass.
- Then, adjust the horizontal screw to align the door flush with the side.
- Finally, adjust the depth: This setting ensures that the door does not stick when closing.
This three-step process ensures the door closes smoothly without catching. It is important to make only minimal adjustments to each screw and check the door after each step.
