ᐅ Are there any experiences with retrofitting soft-close mechanisms on IKEA Brimnes furniture?
Created on: 29 Jun 2023 18:07
Austinse55
I would like to start a discussion about retrofitting soft-close mechanisms on IKEA Brimnes furniture. My specific question is: Has anyone already had experience installing soft-close fittings on Brimnes doors? I’m interested because the doors in my furniture often slam loudly, and I’m looking for a simple but durable solution without having to completely rebuild the furniture.
I’m especially interested in the following points:
- Which soft-close mechanisms have you used or found to work well with Brimnes?
- How complex was the retrofit (tools needed, installation instructions, time required)?
- Has the functionality and quality noticeably improved after the retrofit?
- Were there any problems or limitations (e.g., due to the material thickness of the doors or the existing fittings)?
I look forward to your experiences and any tips on suitable products or sources. Thanks in advance!
EDWARD0 schrieb:
If the doors are only 15mm (0.6 inches) thick, I would rather recommend surface-mounted soft-close dampers.Exactly, and honestly, I think the whole soft-close feature on IKEA furniture like Brimnes is often overrated. These pieces are built so cheaply that any surface-mounted damper mostly just masks the issue instead of actually improving it. I would rather suggest buying higher-quality furniture from the start instead of spending time and money on these retrofit solutions.
karlau schrieb:
I would rather recommend buying higher-quality furniture right away instead of spending time and money on such retrofits.That is a valid point. However, for many people, the Brimnes is a great value-for-money piece of furniture, and adding soft-close hinges significantly improves daily usability, especially in open living spaces. I have had good experiences with add-on dampers; they are affordable and work quite well without damaging the furniture frame.
Here is my practical recommendation for retrofitting soft-close on the Brimnes:
- Purchase a set of surface-mounted dampers that are fixed with screws and do not require large boreholes.
- Mark the position on the door frame where the damper will be installed, typically on the upper inner edge.
- Make sure that the doors close properly without sticking.
- If the hinge is adjustable, use the adjustment options for a perfect fit after installation.
With these steps, you can make the closing action noticeably smoother. The effort takes about 20–30 minutes per door. Don’t forget to use a screwdriver or cordless drill and regularly check the alignment.
Austinse551 Jul 2023 07:54Thank you very much for the many helpful tips; I now have a pretty good understanding of the options. One last question: Does anyone have experience with whether retrofitting soft-close mechanisms on Brimnes furniture might affect IKEA’s warranty? Specifically, if I replace the hinges or install dampers myself, could this be considered a modification that would void a claim in case of future damage? Of course, I want to do this properly but also avoid unintentionally losing the warranty.
PeoDaniel1 Jul 2023 09:08Regarding the warranty: IKEA usually offers a limited warranty on furniture. This warranty can indeed become void if you carry out significant modifications on your own, which may include replacing hinges or permanently attaching soft-close dampers.
A small tip from me:
- Soft-close add-on dampers that are installed without permanent drilling in sensitive areas are less problematic.
- Replacing the original fittings always carries some risk concerning the warranty.
It’s best to check your warranty terms or ask IKEA directly—some staff members are quite accommodating, while others are less so.
Otherwise, I can only recommend that you reverse any changes before submitting a warranty claim in case of any issues.
