ᐅ What special considerations are there when installing Ikea Brimnes hinges?
Created on: 9 Apr 2020 14:12
Sanson36Hello everyone, I recently bought an Ikea Brimnes wardrobe and encountered some peculiarities with the hinges during assembly that don’t quite match the standard I’m used to from other furniture. I’m particularly interested in any special designs or functions of the Brimnes hinges, such as how the mechanism is constructed, whether there is a unique type of adjustment, and what challenges this might pose during assembly. Is there anything important to keep in mind when installing these hinges to avoid later problems with door operation or stability? I look forward to your explanations, tips, and experiences!
The distinctive feature of the Ikea Brimnes hinge design lies mainly in the combination of a metal clip mechanism and a hinge arm usually reinforced with plastic. The system is designed so that the hinges can be mounted without tools using a snap-in mechanism, which speeds up assembly but can also pose a safety risk if the user does not properly hear or feel the click. In addition, each hinge fastening element offers dual adjustment options: horizontal and depth adjustment, which are achieved through different screws. Vertical adjustment is usually done with the mounting screws on the cabinet. An often underestimated point is the alignment of the drill holes when replacing hinges independently. Another pitfall is the plastic sleeve that secures the hinge arm to the cabinet – if installed incorrectly, it can break and significantly compromise the stability of the door. Can you specify whether you experienced any issues with the snapping-in or if you had to adjust the doors afterward?
Wyatt schrieb:
Can you specify whether you had trouble with the click-in mechanism or if you had to adjust the doors afterward? Thank you for your detailed response! Yes, that was exactly where I had difficulties. With some hinges, in my opinion, there was hardly any audible click, and I was unsure if they were properly engaged. After that, I did have to adjust the doors several times, especially horizontally. Are there any advantages to the plastic sleeve? I’m worried I might have damaged it by applying too much force.
The sleeve is really a weak point. It has happened to me as well that it broke, which made the door quite unstable. My advice: when hanging it, don’t use excessive force and make sure to align the hinges precisely beforehand. I know it’s frustrating when it doesn’t fit perfectly. Don’t give up, it will work out—you just need to be careful and make good use of the screws for adjustment!
Hey, I initially had some issues with Brimnes hinges too, but they’re really straightforward once you get the hang of it! 🙂 Super practical: the hinges are designed so you can quickly remove and reattach the doors. When adjusting them, you really notice how precise you can set the doors! So keep at it, it’s fun and the result looks great!
