ᐅ What should I do if my IKEA BRIMNES doors are not closing properly?
Created on: 4 Sep 2023 09:17
joakim5
joakim5
4 Sep 2023 09:17
Hello everyone, I have an issue with my Ikea Brimnes wardrobe doors. Recently, they stopped closing properly; they get stuck and sometimes don’t close fully. I have already checked if something is caught in the frame, but I suspect it’s more likely a problem with the mechanism or possibly the hinges. The doors seem slightly warped or might be sagging a bit, which is preventing them from closing smoothly. Has anyone experienced this problem? What specific steps can I take to get the BRIMNES doors to close correctly again? Thanks in advance for any advice.
TEOZAR
4 Sep 2023 09:45
Hello joakim5, I am familiar with your issue with the BRIMNES doors. Often, the problem is caused by the hinges being misaligned due to twisting or heavy use. As a first step, I would recommend adjusting the doors carefully:
- Check the hinges and adjust them with a screwdriver
- Tighten the screws on the hinge plate if necessary
- Inspect whether the hinges are bent or warped
- Make sure the cabinet itself is properly aligned, as sometimes the frame is not installed correctly
If the doors are slightly warped, this can quickly cause them not to close properly on BRIMNES models. A small adjustment often helps. If there is any blockage or adhesive residue on the frame, it is best to carefully remove it using a fine sponge and warm water. Sometimes it also helps to remove the doors briefly, if only for easier adjustment.
gasidney
4 Sep 2023 10:07
Simply check the hinges and adjust them if necessary. Often, loose screws are the reason the door or window won’t close properly.
CARLA
4 Sep 2023 11:12
As a general recommendation, I suggest the following steps initially:
- Check the hinges for proper fit and tension
- Remove the doors and visually inspect them for any warping
- Check the cabinet side panels for flatness, as warped side panels can make closing difficult
- If applicable, inspect hydraulic dampers (if installed)
If the problem persists despite adjustments, there may be defective hinges or damaged guide elements. In that case, replacing the hinges would be advisable.
joakim5
4 Sep 2023 12:48
Thank you very much for your help so far! I have already checked the hinges; they don’t show any visible damage, but not all the screws are tight. Before I adjust too much: What exactly should I keep in mind to avoid making the door alignment worse? Is there a specific procedure or order for tightening and adjusting?
What is the easiest way to access the screws without removing the door completely?
TEOZAR
4 Sep 2023 13:34
Yes, it is important.
- First, loosen all hinge plates on the cabinet body, then slightly loosen all screws on the door side.
- Next, tighten the cabinet screws first to create a stable base.
- Then carefully tighten the screws on the door side and test how the door fits.
- If possible, you can also open and close the doors slightly while adjusting to check the position accurately.
- Avoid applying too much pressure, as this can cause misalignment.
If you proceed carefully and methodically, you can prevent misalignment.
