ᐅ Are there any known construction defects with IKEA Brimnes wardrobes?
Created on: 27 Mar 2022 10:13
V
VINGE
V
VINGE
27 Mar 2022 10:13
Hello everyone, I hope someone here can help me. I am planning to buy an IKEA Brimnes wardrobe and have read some reviews mentioning design flaws. I am specifically interested in whether there are any widely known weaknesses or frequently occurring issues with the construction of this model. This includes, for example, stability concerns, assembly difficulties, or material weaknesses that might become apparent during everyday use. Does anyone have experience or reliable information regarding potential defects with the Brimnes wardrobes? I would like to make an objective decision on whether this investment is worthwhile or if I should consider a different model.
SUBEN60
27 Mar 2022 10:45
Basically, the Brimnes cabinets are solidly built, but there are some known issues: - The back panels are often quite thin and less sturdy, which can affect the overall rigidity of the cabinet. - The supplied screws and fasteners are acceptable for the price but must be assembled precisely to avoid stability problems. - The load capacity of the shelves can be limited if overloaded (e.g., with very heavy items). Careful assembly according to the instructions is important to prevent future issues.
KINMIN4
27 Mar 2022 11:07
I have a Brimnes wardrobe myself. Weak point: the back panel doesn’t hold up well if you move it frequently. Assembly tips: tighten all screws thoroughly, especially the screws on the side panels.
tyson51
27 Mar 2022 12:33
Besides the previously mentioned back panel issue, I have noticed that the hinges on Brimnes cabinets are prone to misalignment. This can cause the doors to not close properly or to stick. A tip: carefully adjust the hinges during installation; it’s worth taking the time for this. Additionally, the load on the shelves should be distributed as evenly as possible to prevent sagging.
Tevin
27 Mar 2022 13:55
I would like to add that, especially during assembly, the sequence and precise tightening of the screws are important to avoid stress on the panels. A common weak point is the attachment of the back panel, often fixed only with small nails – in this case, frequent moving of the cabinet can affect its stability. To prevent this, it is advisable to ensure the back panel fits exactly during assembly and, if necessary, to add additional supports yourself.
angel
28 Mar 2022 08:21
Hello, I have had a Brimnes wardrobe in my bedroom for two years. The assembly instructions are simple, but it is important to follow each step carefully without rushing. After assembly, I noticed small gaps forming around the doors, which I was able to fix by readjusting the hinges. Regarding the material, I would consider the laminate to be delicate – scratches or moisture can damage the surface.
