ᐅ Are there any known construction defects with IKEA Brimnes wardrobes?
Created on: 27 Mar 2022 10:13
V
VINGE
Hello everyone, I hope someone here can help me. I am planning to buy an IKEA Brimnes wardrobe and have read some reviews mentioning design flaws. I am specifically interested in whether there are any widely known weaknesses or frequently occurring issues with the construction of this model. This includes, for example, stability concerns, assembly difficulties, or material weaknesses that might become apparent during everyday use. Does anyone have experience or reliable information regarding potential defects with the Brimnes wardrobes? I would like to make an objective decision on whether this investment is worthwhile or if I should consider a different model.
When assembling Brimnes cabinets, there are a few important points to keep in mind: 1. Back panel: Usually attached with small nails only. It is advisable to align it very carefully and tap it in gently. 2. Screws: All joints must be tightened with the correct torque—too loose will cause instability, too tight can damage the material. 3. Shelves: These are not designed for very heavy loads, so it’s better to distribute heavy clothing or books evenly. 4. Hinges: As mentioned, adjust them precisely to ensure the doors close properly. 5. Moisture protection: Since the engineered wood material used does not tolerate moisture well, avoid placing the furniture in humid rooms or accept reduced durability.
KUDAISY schrieb:
5. Moisture protection: Because the wood-based material used does not tolerate moisture wellThis statement is especially important. The edges are often covered only with a thin foil that can swell when exposed to water. Therefore, I advise against using Brimnes cabinets directly in bathrooms or basements with high humidity. Otherwise, the construction meets the usual standard for this price range.
I find the discussion interesting, but somewhat too cautious. Of course, Brimnes is not a solid wood piece of furniture, but you shouldn’t expect that at this price point. What I find critical, however, is the design of the fittings – in my opinion, they prioritize easy assembly too much over durability. This affects stability in practice, especially if you want to move the cabinet or under higher loads. Unfortunately, customers are often left to deal with these issues on their own, which can lead to frustration after a short time.
SUBEN60 schrieb:
The back panels are often quite thin and less stable, which can affect the overall rigidity of the cabinet.Thank you for this assessment; it matches my observations as well. Are there any recommendations for reinforcing the back panel afterward without affecting the appearance? I am particularly interested in whether an internal reinforcement using additional battens is advisable or if it might be counterproductive.
VINGE schrieb:
Are there any recommendations on how to reinforce the back panel afterwards?Yes, an effective method is to attach thin wooden strips or metal brackets on the inside, fixed discreetly in the corners. Keep in mind: - Avoid placing screws or nails too close to the edges to prevent damaging the material - Use lightweight wood strips to avoid adding unnecessary weight - Lightly installed cross braces can help reduce twisting. Make sure to align the back panel precisely beforehand to avoid any stress buildup.
theota schrieb:
What I find critical, however, is the design of the fittings – in my view, they prioritize ease of assembly over durability.That hits the point quite well. Especially with frequent assembly and disassembly, this can quickly lead to problems. For users who set up the cabinet permanently in one place, this is less of an issue. Therefore, the intended usage should be considered in advance.
