ᐅ How can Ikea Pax glass fronts be cleaned gently?
Created on: 29 Nov 2022 18:37
Z
Zanejon
Z
Zanejon
29 Nov 2022 18:37
Hello everyone, some time ago I bought an Ikea Pax wardrobe with glass fronts and want to clean these glass surfaces gently. Since I have read that harsher cleaning products or abrasive cloths can damage the surface, I am looking for tested methods and tips on how to clean the glass fronts effectively while protecting the material. I am particularly interested in advice regarding the right cleaning solution, suitable cloths, and possibly how to avoid streaks or static buildup. Are there any special home remedies or Ikea-specific recommendations that have proven successful? Thanks in advance for your help!
gasidney
29 Nov 2022 19:03
Hello, I clean the Pax glass fronts with a microfiber cloth and lukewarm water. I completely avoid aggressive cleaners. For tougher stains, I use diluted glass cleaner, but very sparingly.
KUDAISY
29 Nov 2022 19:42
Hello Zanejon, I recommend a multi-step approach for cleaning the Ikea Pax glass fronts:
- Step 1: Remove dust with a soft microfiber cloth to prevent scratches.
- Step 2: Use a solution of warm water with a small amount of mild dishwashing liquid.
- Step 3: Wipe the glass surfaces with the damp cloth, making sure it is not too wet.
- Step 4: Polish again with a second dry, clean microfiber cloth to avoid streaks.
It is important not to use abrasive sponges or aggressive cleaners, as these can damage the glass edges or coatings. I also advise avoiding ammonia or alcohol-based products, as these can cause damage—especially to coated glass.
If water spots remain, diluted vinegar (1 part vinegar, 4 parts water) can help, but use it sparingly and make sure to wipe thoroughly afterward. Good luck!
Dirkmin
29 Nov 2022 20:06
To gently clean the glass fronts of Ikea Pax wardrobes, it is important to consider the material structure. The glass surface is usually tempered or has a light coating, which can be damaged by abrasive or chemically aggressive agents. Therefore, I strongly recommend:
- Using soft, microfiber-based cleaning cloths to avoid mechanical damage.
- Preferably using cleaning products that are water-based with a neutral pH, or very mild dishwashing detergent solutions.
- Avoiding alcohol, ammonia, or all-purpose cleaners containing strong solvents.
To prevent streaks, polishing afterward with a dry microfiber cloth is advisable. Avoiding direct sunlight during cleaning also helps minimize the formation of spots.
BAUEVA
30 Nov 2022 07:15
KUDAISY schrieb:
I would also avoid ammonia or alcohol-based cleaners, as these can especially damage coated glass.
That is an important point. However, I wonder how many users consciously avoid these chemicals, even though they are often present in common glass cleaning products. In everyday household use, convenience often takes priority over preserving the material.
Can anyone share concrete experience on whether, for example, alternative cleaners without ammonia are truly better for Ikea Pax glass fronts in the long run? Also, how effective are they on stubborn stains? Are home remedies like vinegar solutions really the best option here, or just a compromise?
V
vinpau
30 Nov 2022 09:33
Hey, thanks for the great tips so far! I can only confirm that microfiber cloths are worth their weight in gold. I always use a spray of glass cleaner and then the cloth – super convenient! I also think it’s important not to apply too much pressure, so the glass stays beautiful and shiny for a long time. And if you do this regularly, you avoid nasty stains or scratches. Highly recommended, give it a try!
