ᐅ Are there Ikea Pax models with clear glass or frosted glass doors?
Created on: 27 Mar 2015 08:13
Alemni
I am currently planning to purchase cabinets from the Ikea PAX system and am specifically looking for models with clear glass or frosted glass doors. I am aware that there are different door types available for PAX, but I find the information on the Ikea website and in the product catalogs not always clear, especially regarding glass doors.
My questions for you:
- Does Ikea currently offer, or has it occasionally offered, PAX doors with clear glass?
- Are there options for frosted glass fronts in the PAX system?
- What are your experiences with these door fronts in terms of durability, maintenance, and appearance?
I would appreciate it if anyone could share their experiences or provide detailed product information. Thanks in advance!
Thank you for the responses so far; they are already quite helpful!
Regarding your questions, PIN66: I am mainly planning to use hinged doors because I want flexible access to the storage and prefer a classic look. There will be a total of 4 doors, each about 50 cm (20 inches) wide and approximately 236 cm (93 inches) high.
I am also concerned about everyday use—specifically, how resistant the glass doors are to scratches and dirt. Especially since the wardrobes will be in the bedroom, and I don’t want the doors to be too delicate.
Does anyone have direct experience with framed glass doors versus full glass doors in the Pax system? How do these options differ in terms of durability and installation?
Basically, Ikea distinguishes between full glass doors and wooden frame doors with glass inserts in the PAX system. Full glass cabinet doors are recognizable by their delicate appearance and are often made of tempered safety glass to minimize the risk of injury if broken.
Assembly:
- Wooden frame doors are somewhat easier to install because the glass panel is securely fixed and well protected.
- Full glass doors require more careful handling and special hinges, usually with rubber buffers to prevent glass breakage.
Durability:
- Both types are durable enough for everyday use, but framed glass cabinet doors are often more impact-resistant since the frame absorbs the force rather than the glass itself.
- Wear and scratches depend heavily on the type of glass – clear glass requires more maintenance, while frosted glass tends to conceal damage better.
My recommendation: If you expect children or heavy traffic in the room, I would suggest choosing frosted glass framed doors due to their durability and better concealment of scratches.
Assembly:
Durability:
The question about clear glass or frosted glass doors in the PAX system is interesting, as IKEA updates the range from time to time and there are regional differences in availability.
From a technical perspective:
- Clear glass fronts are often made of tempered safety glass or laminated safety glass, which is important in case the doors break—they do not shatter into sharp pieces.
- Frosted glass is achieved through satin-finished tempered or laminated glass, as mentioned, providing more privacy.
The main advantage of glass doors in the PAX system, besides aesthetics, is the way they allow light to enter and the opportunity to use interior lighting effectively, which enhances the overall design.
Regarding maintenance, glass is prone to fingerprints; the texture of frosted glass helps make them less noticeable.
One tip: before buying, you should carefully measure your space and check the correct fittings and door sizes. There are also combinations with mirrors available, if that might be of interest.
What I’m also curious about: have you already chosen the base color and internal structure of the wardrobe? This strongly influences the effect of the glass doors.
The question of choosing PAX doors made of clear glass or frosted glass is quite justified, as the glass options for Ikea PAX are modular and can change over time.
Brief summary:
- "Härnedal" is the standard wood frame door with clear glass, very popular.
- Frosted glass doors are less common and often labeled as "Glass White Matt."
- Full glass doors are rarer and usually found in special collections.
The advantage of wood frame doors with glass is greater stability and easier repair in case of damage.
For your project (4 hinged doors approx. 50x236 cm (20x93 inches)), I specifically recommend paying close attention to the quality of the hinges. Due to their weight, glass doors are more stressed compared to solid wood doors and require sturdy fittings.
If maintenance is important to you: use mild glass cleaners without ammonia and soft cloths to avoid dull spots or scratches.
If you want, I can provide you with the current product numbers listed in the Ikea system.
Brief summary:
harold schrieb:
Installation:
- Timber frame doors are somewhat easier to install because the glass panel is firmly fixed and well protected.
- Full glass doors require more careful handling and special hinges, usually with rubber buffers, to prevent glass breakage.Thank you for the clear explanation. The idea of rubber buffers sounds interesting; is it possible to purchase these hinges separately if replacements are needed?
FAZAR schrieb:
One thing I'm still curious about: Have you already chosen the base color and the interior layout of the cabinet? Because that strongly affects the appearance of the glass doors.Yes, I've chosen a white cabinet color and plan to have the interior fitted with adjustable shelves and pull-out drawers. That visually works best for me in the bedroom.
Thanks again for all the helpful contributions!
Alemni schrieb:
Yes, I chose a white carcass color and plan to have adjustable shelves and pull-out drawers inside. Visually, this works best for me in the bedroom.That matches very well – white carcasses with frosted glass fronts are especially elegant and softly reflect light without revealing too much inside. With clear glass, of course, everything inside is visible; you might want to use storage boxes to keep things looking neat.
Regarding spare parts: Ikea often sells hinge sets separately, especially for PAX. The bumpers are usually part of the hinges and are not available individually, but you can easily get complete sets from Ikea customer service or online. I would recommend ordering a few spare hinges upfront so you’re prepared.
