ᐅ Are there Ikea Pax models with clear glass or frosted glass doors?
Created on: 27 Mar 2015 08:13
Alemni
Alemni
27 Mar 2015 08:13
I am currently planning to purchase cabinets from the Ikea PAX system and am specifically looking for models with clear glass or frosted glass doors. I am aware that there are different door types available for PAX, but I find the information on the Ikea website and in the product catalogs not always clear, especially regarding glass doors.
My questions for you:
- Does Ikea currently offer, or has it occasionally offered, PAX doors with clear glass?
- Are there options for frosted glass fronts in the PAX system?
- What are your experiences with these door fronts in terms of durability, maintenance, and appearance?
I would appreciate it if anyone could share their experiences or provide detailed product information. Thanks in advance!
GIPAPO
27 Mar 2015 08:18
Yes, Ikea offers PAX doors with clear glass and frosted glass, usually referred to as "glass fronts" or "sliding doors with glass." They are listed within the product range, for example the "Härnedal" doors with clear glass. It’s best to check the online shop or visit the store directly.
deoke
27 Mar 2015 09:02
To answer your question in detail: Yes, Ikea offers various PAX doors with glass inserts, available in both clear glass and frosted glass. These doors usually consist of a wooden frame with a large glass panel. The clear glass versions often display the interior visibly, while frosted glass is more translucent and obscures the view somewhat.
There are technically different types:
- Full glass doors, which are somewhat more delicate and should be handled with care.
- Wooden frame doors with glass panels, which tend to be more sturdy.
The "Härnedal" series is a well-known option with clear glass that is affordable and popular. The frosted glass version is often called "Glas Weiß Matt" or something similar.
It is important to pay close attention to the exact measurements when purchasing and also consider the door fittings (e.g., hinges), as some glass doors require special mounting hardware.
What does your planned setup look like exactly? How many doors do you need? I might be able to assist you with the technical planning as well.
baelku
27 Mar 2015 09:18
About six months ago, I installed "Härnedal" clear glass doors on my PAX wardrobe. They look really stylish but are somewhat more delicate than solid wood doors. Maintenance is not difficult, but fingerprints show up quickly.
Elisa
27 Mar 2015 10:03
Yes, there are. Ikea sells PAX doors with clear glass and frosted glass. "Härnedal" is the best-known series with glass. For frosted glass, you need to look a bit more closely, as it is usually listed under "matt glass."
PIN66
27 Mar 2015 11:45
It should be added that the frosted PAX doors typically use satin-finished safety glass, which has the advantage of being less transparent while still allowing light to pass through. This is especially useful if you want to make storage partially visible without having everything completely open.
Another important point is the durability of the glass fronts: to maintain them in the long term, regular and gentle cleaning is advisable to avoid scratches. The hinges and fittings on the glass doors are often reinforced, which should be taken into account during assembly.
If you plan to use sliding doors with glass panels, the tracks should not be underestimated either—there are quality differences here. What are you planning—sliding doors or hinged doors?
