ᐅ Which Ikea Pax doors provide the best sound insulation?
Created on: 7 Aug 2017 09:17
NEMUKE
NEMUKE
7 Aug 2017 09:17
I am currently looking into which Ikea Pax doors offer the best sound insulation. Specifically, I am interested in whether there are significant differences in noise reduction within the Pax series—such as between the wood or glass options, or between the simple sliding doors and the framed hinged doors.
Since I am planning to use the Pax wardrobe for a bedroom, sound insulation is very important to me, both to minimize noise from opening and closing the doors and to reduce external noises as much as possible.
Perhaps there are differences in workmanship, material thickness, or special seals that improve sound insulation? If anyone has experience or measurement data, I would appreciate a detailed evaluation of the different models.
Which doors from the Ikea Pax range would you recommend regarding sound insulation, and why? Are there any alternatives or modifications that could enhance noise reduction?
Thanks in advance for your help!
glamo8
7 Aug 2017 09:45
Wooden hinged doors provide better sound insulation than sliding doors. Sliding doors are thinner and often have fewer seals, which is why they offer less soundproofing.
Rashadmeo
7 Aug 2017 10:03
Very interesting question! I have the Pax sliding doors with glass myself, and I have to say they are more of a source of noise than insulation 😀 If you want quiet, it’s better to go with wooden hinged doors—they feel more solid and provide better sound dampening! 🙂 You can do it!
poted
7 Aug 2017 11:22
To properly assess the sound insulation of Ikea Pax doors, it’s important to consider several factors.
First, the material thickness and door design: solid wood or wood veneer doors generally have a higher mass compared to glass or lightweight panel doors, which positively impacts soundproofing. Additionally, hinged doors usually feature better perimeter seals that reduce external noise more effectively.
Sliding doors, on the other hand, are often thinner, sometimes include large glass panels, and usually lack continuous sealing around the edges, making them less effective at sound isolation. The sliding track mechanism can also generate noise, which might be disturbing in bedrooms.
Furthermore, some doors offer special rubber seals or inserts that can improve acoustic sealing. This option is especially beneficial for hinged doors.
In your case, I would recommend:
- Choosing full-surface, heavy hinged doors
- Selecting models with seals
- Avoiding glass if sound insulation is a priority
Do you have a specific model in mind where we can gather detailed information? For example, "Pax Komplement" or "Pax Berså"? Also, what is the room size and what noise sources are nearby?
NEMUKE
7 Aug 2017 13:07
poted schrieb:
Is there a specific model in mind that we can gather detailed information about? For example, "Pax Komplement" or "Pax Berså"? What is the room size and what noise sources are nearby?
Thank you for the detailed explanation. I am particularly interested in the "Pax Komplement" wooden swing doors and the "Pax Berså" sliding glass doors. The room is about 14 sqm (150 sqft) in size, and it adjoins a hallway that can be quite noisy at times due to the front door and smooth flooring. Therefore, I am looking for a door that can help reduce external noise from the hallway while also operating as quietly as possible when opening and closing.
Does anyone have experience with these two models? How do you find their noise levels and sound insulation performance in everyday use?
glamo8
7 Aug 2017 14:40
NEMUKE schrieb:
Does anyone already have experience with these two models? How do you find the noise level and insulation performance in daily use?
The "Pax Komplement" doors have better seals. The closing mechanism is usually quieter than that of the "Pax Berså" sliding doors, which tend to squeak and offer minimal sealing.
