ᐅ Which Ikea Pax models operate most quietly?
Created on: 26 Apr 2022 09:13
riflo46
riflo46
26 Apr 2022 09:13
Hello everyone, I am currently planning to purchase a new IKEA PAX wardrobe and I am particularly interested in the question: Which IKEA PAX models are especially quiet in use?
I am mainly referring to the noise when opening and closing the doors, as well as the general sounds from the tracks or rollers when moving drawers and hanging rods.
I understand that PAX is a very versatile system, with sliding doors, hinged doors, various interior fittings, and different running mechanisms. But are there any specific differences in noise levels between the different models or variants? Which combinations of doors or tracks are particularly quiet or at least dampened?
I would appreciate it if you could share your own experiences or tips for choosing the quietest possible PAX wardrobe to help me make an informed purchase decision. Thanks in advance!
tolokau
26 Apr 2022 10:45
Hello riflo46,
To address your question clearly, it is important to identify the main sources of noise in the PAX system:
- Sliding doors: These run on rollers in the upper and lower tracks. Higher quality rollers and well-adjusted tracks significantly reduce noise.
- Hinged doors: Usually mounted on hinges, creaking sounds can sometimes occur depending on the hinge quality and installation.
- Drawers: Often have metal or plastic runners with varying sliding properties.
Development notes:
1. Sliding doors with a soft-close function are generally quieter because the closing is dampened. For example, the "PAX TRYSIL" model offers soft-close as an option.
2. Hinged doors with high-quality metal hinges and possibly additional damping close quietly.
3. For drawers, I recommend models with synchronized soft-close metal runners.
Common installation mistakes that cause noise:
- Inadequate adjustment of tracks or hinges
- Lack of lubrication
- Overfilled drawers or uneven loading
Summary:
If your priority is the quietest possible use, I recommend PAX models with soft-close on doors and drawers, high-quality hinges, and regular maintenance. Specifically: PAX with TRYSIL doors or alternatively the versions with hinged fittings and soft-close.
I hope this helps!
gasidney
26 Apr 2022 13:09
I bought PAX with hinged doors and soft-close, which is really quiet. Sliding doors are often noisier, especially without soft-close.
Matthewt48
26 Apr 2022 16:35
Hello riflo46,
I would like to add that the noise level of PAX systems also strongly depends on the surface the wardrobe stands on. On very hard floors, resonance can occur, which may be perceived as loud cracking sounds. Additionally, the quality of the screws and the tightness of the connections influence the noise environment.
My recommendation:
- Make sure to carefully adjust the doors and drawers during assembly.
- Use felt pads or cushioning materials where the furniture contacts the floor.
- For sliding doors, IKEA offers optional soft-close mechanisms that really help.
If possible, test the models at your local IKEA store, as you can get a good sense of the noise there.
Good luck with your purchase!
INGRID34
26 Apr 2022 18:48
I had PAX with sliding doors without soft-close and found it quite noisy. Since replacing them with hinged doors with soft-close, it has been much quieter.
nojaus
27 Apr 2022 07:22
I had a similar experience with the noise when opening. In addition to the tips mentioned, I would also recommend asking at IKEA about any newer models. The technology in PAX systems continues to evolve, and some recent versions are indeed acoustically improved.
In the end, regular maintenance also plays a role – in everyday use, I've noticed many cabinets that are unnecessarily noisy simply due to loose screws or lack of care.
Hang in there, the decision is worth it!
