ᐅ Are there any Ikea PAX models with extra-large drawers?
Created on: 18 Mar 2024 14:37
Lidra69
Lidra69
18 Mar 2024 14:37
I am currently planning a new wardrobe and am particularly interested in the IKEA PAX series, as it offers modular options that I really appreciate. My question is: Are there drawers within the PAX models that are significantly larger—that is, noticeably wider or deeper than the standard drawers, which are often designed only for smaller clothing items or accessories?
I am looking for drawers that would be ideal for storing larger textiles, such as thick sweaters, jeans, or possibly even bedding, in a compact and organized way. Who has experience with the different drawer sizes in the PAX models and can say whether there are specifically larger drawer options?
I look forward to your tips and advice, and also welcome suggestions for alternatives if you know of better solutions.
pa-wolf
18 Mar 2024 15:06
Yes, there are PAX drawers available in different depths and widths. The largest are the 75cm (30 inches) wide and 58cm (23 inches) deep drawers, which you can replace with the standard 50cm (20 inches) wide ones. This is the best option if you need more storage space.
koduga
18 Mar 2024 15:29
I can completely understand your wish, as I have often had difficulties storing larger textiles neatly myself. With PAX, I also looked for larger drawers and found that the maximum width is 75 cm (30 inches). However, that sometimes still didn’t feel big enough. It also helps to customize the interior organization with inserts to suit your own needs.
Lucien
18 Mar 2024 18:42
As a supplement: The IKEA PAX series generally offers two different depths for the wardrobe frames, 35 cm (14 inches) and 58 cm (23 inches). For the drawers, this means they are tailored to the wardrobe depth and accordingly provide either a shallow or more spacious option.
The largest drawers are usually 75 cm (30 inches) wide and 58 cm (23 inches) deep, fitting the larger frame. In terms of height, drawers come in several sizes (approximately 12 cm (5 inches), 20 cm (8 inches), and 40 cm (16 inches)). For larger items, the taller drawers or pull-outs with internal organizers are recommended.
I suggest carefully measuring your clothes or laundry because, by combining width, depth, and height, you can plan very flexibly. Larger drawers are available in the PAX series, but fully “extra-large” drawers in the XXL range with widths over 80 cm (31 inches) do not exist.
kieran
18 Mar 2024 19:11
Lucien schrieb:
The largest drawers are usually 75cm (30 inches) wide and 58cm (23 inches) deep, suitable for the larger frame.
That is correct. Additionally, it should be noted that these dimensions are relatively standardized to ensure compatibility with other PAX components. If you really need larger drawers, you often have to work with the frame specified by IKEA or modify the drawers yourself.
theo63
19 Mar 2024 09:17
I think it’s important to clarify what is meant by "particularly large." Many users refer to greater width, while others mean depth or height.
The PAX models offer up to 75 cm (30 inches) in width, but the depth of standard models is limited to 58 cm (23 inches), which may not be sufficient for some. From my experience, many people opt for custom interior fittings to optimize storage space rather than relying solely on larger drawers.
Perhaps a combination of smaller drawers and shelves with boxes would be more practical than focusing only on extra-large drawers?
