ᐅ How can Ikea PAX drawers be retrofitted with soft-close mechanisms?
Created on: 25 Feb 2022 09:17
JotilmannJ
Jotilmann25 Feb 2022 09:17Hello everyone, I have an Ikea PAX wardrobe system with some existing drawers that unfortunately do not have soft-close functionality. I would like to retrofit this feature to allow for smoother and quieter closing. Since I have no experience retrofitting soft-close mechanisms on Ikea PAX drawers, I would like to know:
What options are available to add soft-close functionality to the existing drawers of the PAX system?
- Are there specific retrofit kits from Ikea or third-party suppliers for PAX?
- How complex is the installation, and is it necessary to modify the drawer slides or drawer construction?
- Are there particular models or manufacturers that are known to be compatible?
I would appreciate any personal experiences, installation tips, or warnings about potential issues!
PECLARISSA25 Feb 2022 09:45Jotilmann schrieb:
I would like to retrofit these to allow for smoother and quieter closing.Sounds like a great idea! 😎 There are actually some neat options for your PAX drawers.
- IKEA doesn’t offer direct soft-close retrofit kits for PAX, but some third-party suppliers have smooth-close systems that can be pretty easily installed on the existing drawer runners.
- It’s important that the soft-close dampers fit the runners exactly; otherwise, installation can become tricky.
- Installation is usually straightforward: remove the drawer, check the runners, attach the dampers, and you’re done!
Don’t worry, you can easily manage it—and then no drawer will slam shut anymore. 😉
For clarification: Ikea currently does not offer official soft-close retrofit kits for PAX drawers.
Third-party manufacturers like Blum or Hettich produce compatible soft-close runners, which usually require a complete replacement of the drawer slides.
Installation instructions:
- Replace old runners with simple ball bearing mechanisms with soft-close models
- Remove the drawer completely
- Install the new runners according to the assembly instructions
It is advisable to confirm the exact measurements (drawer width, depth) before purchasing, as some systems are designed for standard sizes.
For precise retrofitting of soft-close mechanisms on Ikea PAX drawers, I recommend the following approach:
First, check which type of drawer slide is currently installed: Ikea typically uses either Metabox or suspension slides. Both systems differ in construction and require different soft-close solutions.
- Metabox: There are third-party kits available that allow relatively simple retrofitting of soft-close. The dampers are usually attached to the inside of the slide.
- Suspension slides: Soft-close options are harder to find for these, and often a complete replacement of the slide is necessary.
It is important to measure the drawer depth, width, and choice of slide.
Installation:
- Fully remove the drawer from the cabinet
- Carefully remove the drawer slides
- Attach the new soft-close slides or retrofit dampers
- Reinstall and adjust the drawer
A potential issue is that some soft-close units slow the drawer down too much or do not fit properly, so as a tip: check before installation if the drawer still opens smoothly afterward. Also, consider the load capacity depending on how heavily the drawer will be filled.
If you are technically proficient, this should be quite feasible. If not, it might be worth consulting a carpenter or furniture fitter.
Installation:
In addition to the previous points: Make sure that with retrofit solutions, the load capacity and smoothness of operation are appropriate, as Ikea PAX is a sturdy construction.
A successful retrofit process requires:
- Compatibility of the drawer slides
- High-quality soft-close mechanism (for example, Blum offers reliable products)
- Continuous adjustment of the drawer fronts after installation
If you keep these points in mind, you will notice improvements both visually and functionally.
