ᐅ How do I replace warped Malm drawer fronts?
Created on: 1 Aug 2022 09:12
Koanlo
I have noticed that some of the drawer fronts on my IKEA Malm dressers are slightly warped. This not only looks unattractive but also prevents the fronts from closing properly.
My question to the community is: How do you replace warped Malm drawer fronts?
I want to proceed as professionally as possible without damaging the entire drawer mechanism. Are there any special tools I should be aware of, or tricks that make the removal process especially gentle?
Additionally, I am interested to know whether it is necessary to use new IKEA original parts when replacing the fronts, or if there are compatible alternatives.
Thanks in advance for your tips!
Koanlo
3 Aug 2022 09:26
Laukau5 schrieb:
Precisely measuring the dimensions of the old front panel
I will do that, thanks.
I have also found out that my model is from 2017 and the front panels have a matte painted finish.
Thanks also for the tip regarding the position of the drill holes. I will check this carefully when ordering the replacement parts.
If I have any further questions, I will post here again.
Rhett
3 Aug 2022 10:18
I find the topic here quite detailed – in the end, it usually isn’t difficult if you take your time and measure carefully.
WARREN
3 Aug 2022 11:03
One small tip for cleaning clips and fasteners: simply clean the mechanism with a mild cleaner before reinstalling. Dirt can otherwise affect the fit.
Koanlo
4 Aug 2022 07:47
Quick update: This morning I removed the first fronts and followed your advice. The heat application worked really well; using a hairdryer on a low setting made the material flexible enough to remove without breaking.
The clips are a bit delicate, so I carefully released them with a plastic spatula. Thanks for the tip.
I will now order the replacement fronts and will report back once I have finished the installation.
Elodie
4 Aug 2022 08:15
Great, that sounds excellent! 🙂 Thanks for the update – and good luck with the reinstallation. I’m keeping my fingers crossed that everything fits perfectly!
