I recently installed Pax glass doors from Ikea in my apartment and want to take proper care of and clean them without damaging the surfaces or the glass. Since these are glass front panels, I’m unsure whether regular glass cleaners or special products are better suited. I also want to avoid damaging the frames or seals.
Does anyone have experience cleaning Ikea Pax glass fronts? Which products and methods do you recommend? Are there any particular precautions I should take to keep the glass doors looking shiny and to prevent streaks or scratches?
I appreciate any tips!
Hey Reyago,
really important question, especially with such beautiful glass doors you definitely don’t want to make any mistakes! 😎
I usually clean my Pax glass fronts with regular spray glass cleaner. But here’s a little tip: never spray directly onto the glass, always spray onto a microfiber cloth first. This way you avoid the cleaner running onto the frames.
Then simply clean in small circular motions and polish afterwards with a dry, clean cloth – this prevents streaks! Oh, and deep scratches can’t be repaired, so always be gentle.
Best regards and good luck! ✨
Hello Reyago,
to answer your question in more detail: Ikea Pax glass fronts are made of safety glass, which is relatively durable. However, aggressive chemicals such as ammonia- or alcohol-based cleaners should be avoided if possible, as they can dry out or damage seals or plastic frames.
My advice:
- Use warm water with a few drops of mild dishwashing detergent.
- Use soft microfiber cloths, not abrasive sponges or paper towels.
- For drying, use a lint-free cotton cloth.
If smudges or fingerprints are stubborn, you can also use a diluted vinegar solution, which is gentle on the glass.
Be careful when cleaning the frame as well: occasionally clean off detergent residues, but do so gently.
I hope this helps!
My advice:
I hope this helps!
Great topic! I love my Ikea Pax wardrobes with glass doors, but yes, cleaning them can be tricky! 😍
A little tip from me: After cleaning my glass doors, I go over them again with a soft eyeglass cloth – it adds extra shine and prevents streaks.
And one more thing: If you have stubborn dirt that regular wiping won’t remove, just put a little window cleaner on the cloth (not directly on the glass) and gently wipe with light pressure. Then immediately polish dry.
Keep it shiny! 💎
Keep it shiny! 💎
For factual clarification:
- Ikea Pax glass fronts are generally low-maintenance; however, mechanical cleaning tools like abrasive sponges or harsh chemical cleaners should be avoided.
- Glass cleaners containing ammonia can damage the rubber seals and should not be used frequently.
- Neutral, pH-balanced cleaning agents or mild soap solutions are recommended.
- Use dry microfiber cloths without fabric softener, as fabric softener can leave residues.
When used correctly, the frames and glass will remain like new.
