ᐅ How do I properly clean IKEA Metod glass cabinet doors?
Created on: 1 Oct 2019 09:23
Amit36
Amit36
1 Oct 2019 09:23
Hello everyone, I have a specific question regarding the cleaning of Ikea Metod glass fronts and hope to receive expert advice here. The glass fronts of my Metod kitchen are visually appealing but particularly sensitive when it comes to cleaning products and methods. My question is therefore: Which cleaning methods and products are best suited to clean Ikea Metod glass fronts both effectively and gently, without damaging or causing long-term harm to the surface? Are there any special tips for dealing with minor scratches or stubborn stains? I am also interested to know whether conventional glass cleaners are suitable or if there are better alternatives. I look forward to your experiences and well-informed recommendations!
V
vinpau
1 Oct 2019 10:47
Hey Amit36, great that you asked your question in such detail – it makes it easier for everyone to provide helpful answers! 😊 I’ve had Metod glass fronts for several years myself and swear by a combination of lukewarm water and a mild dish soap. I use this to clean the fronts without leaving streaks or causing damage. It’s important to use a soft microfiber cloth to avoid scratches! For stubborn stains, I use a little white vinegar diluted with water, which works really well and gently. I would avoid harsh glass cleaners, as their solvents can damage the surface. Give it a try and don’t give up if it’s not perfect the first time – practice makes perfect! Good luck!
SUBEN60
1 Oct 2019 11:12
vinpau schrieb:
For stubborn stains, I use a little white vinegar diluted with water; it really works well and is gentle.
Vinegar can indeed be a good option but should be used cautiously, as high concentrations may potentially damage the finish. My recommendation is based on thorough research: for Ikea Metod glass fronts, only neutral cleaning agents with a pH close to 7 are suitable, and cleaners containing ammonia or alcohol should be avoided. A soft, damp cloth without abrasive agents is preferable. Additionally, cleaning should always be wiped off immediately with a dry cloth to prevent water spots. For scratches, I recommend preventive measures, as repairing glass fronts can be difficult. In general, avoid abrasives or rough sponges.
Tommy38
2 Oct 2019 08:10
Hello Amit36, I can only agree with Suben60 and would like to add: The Metod glass fronts are made of safety glass with a coating that not only shines but is also prone to scratches and chemical damage. Therefore, I recommend the following cleaning steps:
- Always use a lint-free, soft microfiber cloth.
- Avoid strongly alkaline or acidic cleaners.
- Lukewarm water with a few drops of mild dish soap is the best base.
- For stubborn stains, you can carefully use diluted vinegar, but always test it first in an inconspicuous area.
- Avoid glass scrapers or abrasive tools.
If you have already noticed minor scratches, a special glass polishing agent might be an option, but only after thorough research and preferably with professional advice to avoid causing further damage. It is important to clean the glass fronts regularly, not just occasionally, to prevent dirt from embedding.
reoWilhelm
2 Oct 2019 12:36
Amit36 schrieb:
Which cleaning methods and products are best suited to effectively and gently clean Ikea Metod glass fronts without damaging or harming the surface in the long term?
Hi Amit36, I can share a little tip with you 😊 I personally like to use distilled water and a special glass cleaner that doesn’t contain harsh chemicals. Sounds simple, but it really leaves a nice streak-free shine! I also make sure the cloth is only damp, not dripping wet, to avoid water spots. It’s really important to treat the fronts gently—no scrubbing hard or using abrasive sponges. A little tip: always clean in the direction of the grain (if visible). This helps keep the surface looking great. Good luck with the microfiber cloth mission! 😉
laureo
3 Oct 2019 07:55
Tommy38 schrieb:
If you have already noticed minor scratches, a special glass polish could be an option, but only after thorough research and preferably with professional advice to avoid causing further damage.
I want to emphasize this point. Especially with Ikea Metod glass fronts, caution is advised because lubricants, polishing pastes, or even DIY home remedies can often cause more harm than good. If the scratches are bothersome, it is recommended to contact the manufacturer or a specialist partner directly for replacement fronts or professional repair. For everyday cleaning, mild agents and the mentioned methods are completely sufficient. Additionally, I recommend never allowing direct sunlight on freshly cleaned fronts, as rapid drying can cause stains.
