ᐅ How can I properly clean and maintain Ikea Pax glass doors?
Created on: 22 Mar 2023 19:07
di-par
di-par
22 Mar 2023 19:07
Hello everyone, I recently got an Ikea Pax wardrobe system with glass fronts and want to clean and maintain them carefully and for the long term. Therefore, I have the question: How do I properly clean and care for Ikea Pax glass fronts so that the surface is not damaged, no unsightly streaks or residues occur, and the shine lasts a long time? Are there any special cleaning products, methods, or care tips that should definitely be followed? I am especially interested in whether conventional glass cleaners can be used or if the glass might be sensitive to certain ingredients. Also, I would like to know the best way to remove fingerprints and whether it is advisable to care for the frames or seals separately. Thanks in advance for your helpful tips!
kulau
22 Mar 2023 20:43
Hello di-par, your question is very well formulated and shows that you are genuinely considering the proper cleaning and care of glass fronts. In general, when dealing with Ikea Pax glass fronts, you should keep the following in mind:
- Avoid using aggressive or abrasive cleaners, as these can damage the glass surface or the frame. This especially applies to cleaning pastes, scouring pads, or products containing ammonia, which can leave stains on certain glass surfaces.
- A damp microfiber cloth is usually sufficient to remove fingerprints and dust without leaving streaks. For stubborn dirt, a conventional alcohol-based glass cleaner can be used sparingly and not too often.
- Make sure the cloth is clean and lint-free, as microfiber cloths often cause streaks if they are dirty.
- If your glass fronts are surrounded by frames or seals, these should be cleaned separately – usually a slightly damp cloth is enough. For plastic seals, occasional wiping with mild dish soap helps.
- Avoid spraying water directly onto the glass front; it is better to spray onto the cloth first and then wipe.
How often you clean depends on usage. For ongoing care, I recommend cleaning fingerprints or spots as soon as they are visible to prevent them from setting in.
I would also be interested to know if you have a special glass coating or if it is just standard glass? This would influence the choice of cleaning products.
LEEJU
22 Mar 2023 21:09
Glass fronts from Ikea Pax are best cleaned with a damp, soft microfiber cloth and regular glass cleaner. Do not spray directly onto the glass; spray onto the cloth instead. Avoid using abrasive cleaners or harsh chemicals.
CHENFAR
23 Mar 2023 08:51
kulau schrieb:
Do not use abrasive or harsh cleaners, as they can damage the glass surface or the frame.
I agree with this and would like to add that cleaning products containing ammonia or high concentrations of alcohol can especially harm the glass and, above all, the coating on glass facades.
It is recommended to clean with a mild, neutral detergent, such as a common glass cleaner with low alcohol content or simply water dampened on a microfiber cloth.
Fingerprints are best removed by gently wiping in circular motions with a microfiber cloth, applying minimal pressure.
For frame maintenance, I suggest regularly wiping them with a slightly damp cloth. Depending on the material of the frames and seals, a special care product might be necessary; caution is advised to avoid leaving residues on the glass.
In summary:
- Microfiber cloth + mild detergent
- No abrasive cleaners or harsh chemicals
- Clean and maintain frames separately
- Do not spray directly onto the glass
If you have sensitive surfaces, test cleaning products first on an inconspicuous area.
warrenka57
23 Mar 2023 14:33
I completely understand why proper care of your Ikea Pax glass fronts is important to you, as I was also dissatisfied for a long time with streaks and residue.
di-par schrieb:
How do I properly clean and maintain Ikea Pax glass fronts so that the surface is not damaged, no unsightly streaks or residue appear, and the shine lasts for a long time?
I have had great results by following this routine:
- Use a soft, clean microfiber cloth. It should not be too old or dirty.
- Apply only a small amount of glass cleaner to the cloth; never spray it directly onto the glass.
- After cleaning, polish with a dry microfiber cloth – this helps to avoid streaks.
If you are sensitive to cleaning products or have children at home, I recommend using glass cleaners with natural ingredients.
Regarding the seals: I clean them regularly with a damp cloth and dry them thoroughly to prevent dust and mold buildup.
I also know how frustrating it can be when stains or streaks remain despite all efforts – give it a try, and hopefully you will find the perfect method for yourself.
SETHBLA
24 Mar 2023 09:16
This is the most important tip.
Clean the glass surfaces with a small amount of glass cleaner applied to a soft cloth, then wipe again with a dry cloth. Never use abrasive cleaners.
Fingerprints come off quickly this way, and the glass stays shiny. Everything else is overkill.
