ᐅ How can I properly clean IKEA Metod glass fronts to achieve a streak-free finish?
Created on: 14 Jan 2016 08:37
Buryder61
Hello everyone, I am looking for a proper and streak-free method to clean the glass fronts of my IKEA Metod kitchen. The fronts are durable, but I want to avoid damaging them with the wrong cleaning agents or techniques, or leaving unsightly streaks. Which cleaning products work best, and what procedure has proven effective for you to gently clean the surface and achieve an optimal result without streaks or residue?
After reading the previous tips, I would like to add some common mistakes that often cause streaks on IKEA Metod glass fronts: - Using too much cleaning agent: it’s better to use a small amount and apply multiple times if needed. - Spraying directly onto the glass surfaces, which can cause liquid to seep into the joints. - Using unsuitable cloths: cotton can leave fibers behind, and paper towels tend to tear easily. - Forgetting to wipe again or insufficiently drying the surface.
If you keep these points in mind and polish dry with a good microfiber cloth, you will often achieve very good results. For the final polish, I recommend a soft, dry cloth without any cleaning agent—the mechanical action makes the difference here.
mauviniciu15 Jan 2016 08:29Just a quick addition: Warm water and a drop of dish soap, clean with a microfiber cloth, then wipe dry. No additional cleaning agents are necessary.
rotofra schrieb:
Never spray the cleaner directly onto the glass surface; instead, dampen the cloth. This helps prevent too much moisture from accumulating on the edges. This is a very important tip that I can also fully agree with. Additionally, I have noticed that aggressive cleaners can eventually damage the seal or coating on IKEA Metod glass fronts. Therefore, I would recommend using mild cleaners on delicate or new surfaces and, in the case of stubborn dirt, wiping again with clean water. Some users also recommend using soft polishing cloths specially designed for glass. This might be worth trying if you still see streaks.
putan schrieb:
For glass fronts, the classic "water + a drop of dish soap" is often enough.Exactly, that is a simple approach that works very well.
PRA64 schrieb:
After reading the previous tips, I would like to add some common mistakes that often cause streaks on IKEA Metod glass fronts Listing these mistakes is very helpful—especially for users who are impatient and apply too much cleaner. I would also like to add that the quality of microfiber cloths plays an important role. Cheap cloths can often shed more fibers and leave streaks. For glass fronts, I recommend high-quality microfiber cloths that are specifically marketed for glass surfaces. Combined with gentle cleaning, this is the best method to keep the fronts not only clean but also looking good for a long time.
