ᐅ How do I clean IKEA Metod kitchen cabinets when they are heavily soiled?
Created on: 29 Sep 2020 08:37
Anbo36
I have an IKEA Metod kitchen where stubborn dirt has built up over time on the furniture surfaces, especially on the fronts and the edges of the worktops. This is not just superficial dirt or grease, but dried-on and partly discolored spots that standard cleaning products hardly remove anymore. My question is: How can IKEA Metod kitchen furniture be cleaned thoroughly and safely when heavily soiled? Which cleaning agents or home remedies are truly effective without damaging the surface? Additionally, I am interested in whether there are specific methods or precautions to maintain the furniture’s quality in the long term.
Anbo36 schrieb:
The surfaces of my Metod furniture are matte laminated, not painted. The stains are mostly burnt-in grease and partially discolorations caused by contact with certain foods, for example tomato sauce.This is an important point. Maintenance of matte laminated surfaces is indeed delicate since the matte finish can be easily damaged by aggressive cleaning. In addition to what has already been mentioned, I recommend cleaning in several steps. For discolorations caused by tomato sauce, it can help to first moisten the affected area with cold water before applying dish soap. This prevents the color pigments from setting in further.
I would also suggest the following classic approach:
- Wear gloves to protect your skin and the furniture
- Soak with warm water and a mild dish detergent for 10 minutes
- Then gently rub with a soft microfiber cloth
- For tomato or color stains, you can dab with a sponge and a small amount of diluted isopropanol
- Immediately rinse and dry the surface afterward
Be sure not to use too much cleaning agent or leave it on too long, as this can damage the laminate finish.
Here is a structured guide with precise steps for treating heavy stains on IKEA Metod kitchen cabinets (matte laminated):
1. Remove loose dirt with a dry microfiber cloth.
2. Prepare a cleaning solution using lukewarm water and 2-3 drops of mild dish soap.
3. Moisten a clean cloth with the solution and wring it out well, so it is damp but not dripping.
4. Gently wipe the surface and let the solution sit for up to 5 minutes.
5. For stubborn grease stains: make a baking soda paste (sodium bicarbonate + a little water), apply it thinly, and leave it for 5 minutes.
6. Remove the paste with a damp cloth and thoroughly wipe off any remaining residue.
7. For intense discolorations, after testing in an inconspicuous area, carefully dab with a small amount of isopropanol without rubbing.
8. Wipe everything with a dry cloth and allow it to dry completely.
Important: Never use abrasive pads or harsh chemical cleaners, as these can damage the laminate. After cleaning and once the surface is dry, apply a special care cream designed for laminated surfaces to keep the material supple.
praWarre691 Oct 2020 07:58mabla schrieb:
For heavily ingrained dirt, I recommend:
- Soften grease with warm water and dish soap
- Use a baking soda paste for stubborn stains
- Don’t scrub; let it soak instead
- Wipe clean with a damp cloth
- Dry the surface thoroughlyIf you take the process slowly and carefully like this, you have a good chance of making your Metod kitchen look like new again!
Sometimes less is more. It’s better to treat it patiently multiple times than to rub hard and ruin the cabinet. 🙂
