ᐅ How can I clean matte Ikea Metod cabinet fronts without causing discoloration?
Created on: 18 May 2018 08:17
Z
Zarnisha31
I have a question about cleaning my matte IKEA Metod kitchen cabinet fronts. I’ve noticed that conventional cleaning products often cause discoloration or stains that are difficult to remove. Therefore, I would like to know the best way to clean matte fronts without causing unwanted discoloration. Are there specific cleaning agents or techniques that are particularly gentle yet effective against grease, fingerprints, and other dirt? I want to avoid dulling or staining the surfaces with harsh chemicals.
Thank you in advance for your tips!
gauvin37
18 May 2018 10:48
Under no circumstances use aggressive cleaners. The surface will deteriorate quickly. Use only gentle products and soft cloths.
trevor
18 May 2018 11:15
tabau70 schrieb:
A quick tip: Occasionally using furniture polish for matte surfaces refreshes and offers some protection.
Good advice! You can tell you’ve got this under control 😄. By the way, I find it handy to lightly buff with a dry cotton cloth after cleaning. I do this on my doors – it gives a great, streak-free finish.
Nicksin
18 May 2018 11:39
Keeping matte fronts clean is truly an art! Especially with Metod, gentle care is key. I often use a small amount of mild dish soap mixed with water and a clean microfiber cloth. Avoid harsh chemicals or scrubbing brushes. If the dirt is really stubborn, a little vinegar in the water can help, but use it very carefully and wipe thoroughly afterwards to prevent streaks.
Z
Zarnisha31
18 May 2018 13:05
REOHEINRIC schrieb:
Do not use abrasive cleaners or alcohol-based products, as they can dull or discolor the surface
Thank you, that’s important! I once accidentally used an alcohol-based cleaner, and after that, my cabinet fronts no longer had a consistent matte finish.
Can anyone share experience with using citric acid as a cleaner? It was recommended to me, but I’m worried about discoloration or stains.
REOHEINRIC
18 May 2018 13:47
Zarnisha31 schrieb:
Can anyone share their experience with citric acid as a cleaner?
Citric acid is a mild acid and can cause discoloration on certain materials, especially on painted or melamine-coated surfaces like Metod fronts.
I generally advise against using citric acid on these surfaces, as it can damage the paint and cause staining or dull spots. It’s better to stick to mild, pH-neutral cleaning agents.
lis64
18 May 2018 14:32
Citric acid – avoid it! I had exactly the problem that fronts became spotty after cleaning with lemon. Better to use mild dish soap and a microfiber cloth.
