ᐅ How do I clean IKEA Metod kitchen cabinets when they are heavily soiled?
Created on: 29 Sep 2020 08:37
Anbo36I have an IKEA Metod kitchen where stubborn dirt has built up over time on the furniture surfaces, especially on the fronts and the edges of the worktops. This is not just superficial dirt or grease, but dried-on and partly discolored spots that standard cleaning products hardly remove anymore. My question is: How can IKEA Metod kitchen furniture be cleaned thoroughly and safely when heavily soiled? Which cleaning agents or home remedies are truly effective without damaging the surface? Additionally, I am interested in whether there are specific methods or precautions to maintain the furniture’s quality in the long term.
This is a very good and practical question, especially since IKEA Metod furniture is often made from coated particleboard or MDF with a smooth or matte finish, which can be quite sensitive. Generally, I would recommend following these steps to effectively and gently remove stubborn stains:
- Always start with a soft cloth and lukewarm water plus a small amount of mild dish soap for a basic cleaning. This will remove surface dirt.
- For dried grease stains, special kitchen cleaners with grease-dissolving ingredients, ideally enzyme-based, work well. Be sure to follow the dosage instructions, as strong concentrates can damage the surface.
- If the stains are very stubborn, you can carefully try using a sponge or microfiber cloth, but never use aggressive scouring agents or rough sponges, as these can scratch the coating.
- For discoloration, a home remedy often helps: apply a paste made of baking soda and water, let it sit for a few minutes, then gently wipe it off. This method is gentler than chemical bleaches.
It is important to always wipe the surface thoroughly with clean water after cleaning and dry it well to prevent water spots and swelling.
Could you please describe in more detail whether the stains are mainly grease, lime scale, paint residues, or something else? And whether the surfaces are matte, glossy, or laminated? This will help provide more precise advice.
In addition to lorena’s explanations, I would recommend dividing the cleaning process into three clear steps:
- Preparation: First, remove coarse dirt with a dry cloth. Avoid using sharp edges or metal objects to prevent scratches.
- Cleaning: Use a solution of warm water and a neutral dish soap, as lorena described. For tough stains, a baking soda paste is a very good option because it is mildly abrasive but still gentle on the surface.
- Aftercare: After thorough cleaning, you can treat the furniture surfaces with special care oils or lotions designed for coated wood and plastic surfaces. These create a protective layer and help make future dirt easier to remove.
Common mistakes include, as already mentioned, using aggressive solvents such as acetone, turpentine, or bleach, which damage the surface. High-pressure washers should also be avoided.
I also recommend testing any new cleaning method on an inconspicuous area first. This helps prevent unwanted surprises.
Could you please also let me know if your surfaces have a specific protective layer (e.g., film, lacquer, melamine) and how old your furniture is?
Thank you very much for the detailed advice! The surfaces of my Metod furniture are matte laminated, not painted. The stains mostly consist of baked-on grease and partly discoloration caused by contact with certain foods, such as tomato sauce. The furniture is about 4 years old, and I suspect that the grease residues built up from frequent cooking and have dried in firmly over time. No protective treatment, such as maintenance oil, has been applied so far. So targeted aftercare following cleaning might be useful—I’ll keep that in mind. I will test the baking soda paste on an inconspicuous spot first, but before that, I would like to know if there are any other home remedies you would recommend and whether warm or cold water is better when cleaning such matte laminated surfaces?
Thank you for the detailed feedback! With matte laminated surfaces, it is really important not to use overly aggressive cleaning agents, as these can make the laminate appear dull and lifeless.
Regarding your question about water: warm water is preferable because it improves grease removal. However, it should not be too hot to avoid softening the laminate. Lukewarm water is sufficient.
In addition to baking soda, I also recommend diluted vinegar for stubborn limescale stains, but use it very carefully and never leave it on for long, as vinegar can damage the laminated finish. Therefore, as with all cleaning agents, apply briefly, neutralize immediately, and rinse thoroughly afterward.
Another home remedy is dish soap mixed with water and a little lemon juice; this has a mild grease-cutting effect and is gentle. You can also try isopropanol—it is commonly used as a household disinfectant and removes grease without strong abrasion, but only in diluted form.
If you like, I can write a short guide on how to apply these methods safely and effectively.
For heavily ingrained dirt, I recommend:
- Soften grease with warm water and dish soap
- Use a baking soda paste for stubborn stains
- Do not scrub; let it soak instead
- Follow up by cleaning with a damp cloth
- Dry the surface thoroughly
Do not use abrasive cleaners or harsh chemicals!
