ᐅ What is the best way to clean the surface of Ikea BRIMNES furniture?
Created on: 2 Oct 2024 09:17
sugabriele
sugabriele
2 Oct 2024 09:17
Hello everyone, some time ago I bought a few pieces of furniture from the Ikea Brimnes series, mainly dressers and cabinets with a white, smooth surface. Now I’m wondering which methods or cleaning products are best suited to thoroughly and gently clean the surface of these furniture items without causing dullness or damage. I’ve read that some harsh cleaners can harm the finish, while very mild products might not remove dirt effectively. What experiences have you had with this, and what do you recommend for regular maintenance? Thanks in advance for your helpful tips and advice!
koduga
2 Oct 2024 09:45
Hello sugabriele, I understand your concern. The BRIMNES surfaces are not solid wood but are coated with a lacquer or melamine finish, which can be sensitive. I have cleaned my dresser several times and have always had good results using a soft, damp microfiber cloth with a little mild dish soap. It’s important not to use too much liquid and to dry the surface immediately afterward to avoid water spots. After a while, I became more confident and occasionally use vinegar water when light limescale or greasy spots appear. So far, I haven’t had any problems, but it’s always best to test carefully first.
ju_ren
2 Oct 2024 10:03
Simply clean with lukewarm water and a few drops of mild dish soap using a soft cloth. Do not wipe with excessive moisture; dry immediately afterwards. Do not use abrasive cleaners or harsh chemicals.
KAULIS
2 Oct 2024 11:21
The surface of the Ikea BRIMNES furniture is typically coated with melamine, which is relatively durable but sensitive to abrasive or alkaline cleaners. The recommendations are:
- Clean with a damp, soft cloth
- Use neutral cleaning agents, such as mild dish soap
- Avoid scouring powders, solvents, or harsh chemicals
- For tougher stains, use a specialized furniture cleaner suitable for coated surfaces
After cleaning, the surface should be thoroughly dried to prevent damage caused by moisture penetration.
GALEO4
2 Oct 2024 11:48
Honestly, I’m not a fan of all the 'gentle and cautious' advice. The BRIMNES furniture is produced so cheaply that the surfaces aren’t very durable anyway. So why not just give them a good clean with vinegar-based cleaner or baking soda? Sure, the furniture will wear over time, but that happens with any stuff after a few years. If you want it to be clean, you have to put in some effort and not always listen to these stories about handling everything so gently.
koduga
2 Oct 2024 12:15
GALEO4 schrieb:
I don't really agree with the whole 'mild and cautious' recommendation, to be honest.
I can understand this viewpoint, but I believe a balanced approach makes sense. I don’t want to unnecessarily damage my furniture because I like to use it for a long time and not have to replace it constantly. Also, I think especially with affordable furniture, a certain level of care is reasonable to promote sustainable use.
