ᐅ How can I convert an Ikea BESTA unit into a countertop to create a practical work surface?
Created on: 20 Dec 2020 07:43
Nugabriele
Hello everyone, I am currently planning a small DIY project and want to install a countertop on top of the Ikea Besta shelving unit to create a practical workspace. My main question is: How can I securely mount a stable, functional, and visually appealing countertop on a Besta unit without it slipping or getting damaged? I would also like to know which materials are recommended and if there are any special considerations for fastening, especially if I plan to use a thicker countertop. Are there any tips for preparing the Besta unit and choosing the right height for ergonomic working? I appreciate any advice, as I am relatively new to this kind of furniture modification.
Plywood is well suited for the project you have planned because it has a smooth, even surface and is easy to work with. Make sure to seal it with a clear varnish or parquet lacquer that is abrasion-resistant and chemically durable.
Alternatively, you could choose birch plywood, which has an attractive appearance and is very stable. If you plan to refinish the surface occasionally, avoid heavily impregnated sheets, as they can make sanding more difficult.
It is also important to protect the joints at the edges, as these areas are more vulnerable.
Important when installing a countertop on BESTA:
- Secure the countertop firmly with flat, sturdy brackets to prevent any lateral movement.
- Ensure the surface of the shelf is clean to avoid solvents damaging the underside.
- Choose a countertop with a minimum thickness of 18 mm (0.7 inches) for adequate stability.
- For the height: Keep in mind that BESTA shelves are often low, so consider adding leg extensions or a base.
This way, you will achieve a stable and ergonomic workspace.
