ᐅ How can I cheaply repair a damaged surface on an Ikea Besta unit?
Created on: 21 Feb 2021 08:17
Taus37
I have owned an Ikea Besta piece of furniture for some time now, which I actually like a lot, but unfortunately the surface has worn or been damaged in some areas. Specifically, there are small scratches and spots where the paint or veneer has slightly peeled off. It is important to me that the repair stays as inexpensive as possible since it is just a cosmetic issue and I am not expecting a professional-level solution.
Has anyone had experience with how to best repair these kinds of surfaces on Ikea Besta furniture by yourself? What products or techniques would you recommend to discreetly and affordably fix the damage without having to buy expensive specialty items?
I look forward to any tips, instructions, or suggestions on materials that would allow me to carry out an acceptable and low-cost repair on my own.
nofomu schrieb:
try using furniture repair wax or color-matched wax sticks.Thanks for the tip! Is there a specific brand or product you would recommend? Especially if the wood finish is on the lighter side?
hauklo schrieb:
For chipped veneer, it’s advisable to reattach it using double-sided tape and color-matched chalkboard film fabric.That sounds interesting – is the chalkboard film material easy to cut and apply smoothly without bubbles? Or are there practical tips on how to get a clean finish?
Taus37 schrieb:
Is there a specific brand or product you would recommend?At hardware stores, you can usually find sets of furniture wax in different shades, for example from “Auro” or “Uniform.”
Taus37 schrieb:
Is the chalkboard film material easy to cut and apply smoothly?Yes, it can be smoothed out well using a squeegee or a credit card. It is important to clean the surface beforehand to remove any dirt or grease.
Hey Taus37!
That sounds like a typical surface repair challenge—but don’t worry, you’ll manage it! 😌 Here’s a little tip from me: if you’re using wax, warm it up briefly beforehand (for example, in your hand or near a heater), so it works much better when filling in the scratches.
The idea with the chalkboard film is really clever, especially if there’s a larger area. And yes, another easy tip: if small bubbles form while applying it, you can gently prick them with a fine needle and smooth them out.
Good luck, it’ll definitely turn out great!
hauklo schrieb:
If the foil peels off, it is recommended to reattach it using double-sided tape and a color-matched chalkboard film fabricI did this myself on my Besta unit, and it looks great! Important: apply the chalkboard film in one smooth motion with a bit of practice. It’s like applying window film 😉 After that, the small scratches are hardly noticeable anymore.
dijan schrieb:
Wood filler or putty in the matching colorThanks for the tip! A quick question: For white Ikea Besta surfaces or lighter wood finishes, is there a preferred color tone for the touch-up pen, or is it better to mix your own?
Also, how well does it hold up on surfaces that get more wear and tear, for example, if you place items on it frequently?
I'm a bit skeptical whether it will chip off too quickly over time.
