ᐅ Are there any upgrades available for Ikea BESTA to improve its stability under load?
Created on: 16 Dec 2018 08:23
Fajukla
Are there any upgrades for Ikea Besta to improve stability under load?
I plan to combine several BESTA units into a large TV cabinet that may occasionally hold heavy items – including somewhat heavier devices like an AV receiver, gaming console, and some collectibles. I understand that the Ikea BESTA series is basically modular and designed more for lightweight construction.
I am especially interested in whether there are reliable and practical ways to increase stability and load capacity – whether through additional bracing, special screws, sturdy back panels, or other methods that have proven effective in practice.
Can you share experiences, recommendations, or concrete suggestions on how to reliably upgrade these shelves without fundamentally changing the original appearance?
MANUEL
16 Dec 2018 13:23
A technique widely recommended by everyone is to install so-called "furring strips" made of wood. They can be screwed to the edges on the inside and significantly increase stiffness.
theota
17 Dec 2018 07:51
I notice that there is a lot of talk about additional reinforcement measures here, but the real issue is the material itself. Unfortunately, IKEA uses inexpensive particle board and thin fittings for Besta. A few corner braces don’t fundamentally change that – it’s a lightweight shelving unit.
I would rather recommend choosing a different furniture series for high load requirements or using Besta as a visual base and reinforcing the inside completely with your own sturdy wood.
Otherwise, you quickly end up with a "temporary solution" that may look better but no longer resembles the original on the outside.
Muso4
17 Dec 2018 08:15
theota schrieb:
Unfortunately, IKEA uses cheap particleboard and thin fittings for BESTA.
I agree, the choice of materials is the limiting factor. Nevertheless, with a proper back panel and reinforcements, you can bring it up to a solid level. If you want more, you really should consider professional upgrades or invest elsewhere.
Fajukla
17 Dec 2018 12:49
theota schrieb:
I would rather recommend choosing a different furniture series for high load requirements or to use the BESTA as a visual base and reinforce the interior completely with your own solid wood.
Thank you for this assessment. I do plan to keep the appearance but do not want to start completely from scratch. In that case, a retrofitted reinforcement made of wood would probably be the best compromise – I would appreciate tips on which wood types or construction methods are particularly suitable for this.
TELAHAU
18 Dec 2018 14:03
For reinforcement, I recommend 12 mm (0.5 inch) plywood. It is strong, relatively lightweight, and easy to work with.
Additionally, simple metal brackets can be used, which are attached to the inside corners, for example, beneath the shelves, to reduce bending.
meGreg
19 Dec 2018 09:21
The best advice remains: Don’t make it too complicated and enjoy the building process. 😄 Plywood is the DIY enthusiast’s friend and works perfectly combined with the simple BESTA fronts. Nothing will stand in the way of your sturdy piece of furniture!
