ᐅ Are there effective methods to increase the load capacity of Ikea Besta furniture?
Created on: 11 Feb 2020 08:47
Dopo32
Dopo32
11 Feb 2020 08:47
I am currently researching whether there are effective methods to significantly increase the load-bearing capacity of Ikea Besta furniture. Specifically, I want to know how to load these shelves or cabinets more heavily without compromising their stability or safety.
I understand that Ikea products are generally designed for household use, often featuring relatively thin panels and fittings. I am interested to hear if anyone has practical experience or proven techniques to achieve higher load capacity, for example through reinforcements, additional fastenings, or other structural modifications.
Perhaps there are also support frames or special constructions that can be added to make the furniture sturdier. It is important to me that the solutions are feasible for DIY work and do not drastically alter the original design of the Besta modules.
I look forward to your tips, experiences, and recommendations!
leomo
11 Feb 2020 09:12
Good morning!
Interesting topic – Ikea Besta is often quite flexible, but when it comes to load capacity, there’s actually quite a lot you can do! 😄
One idea: you can reinforce the interior with relatively simple methods. For example, adding extra brackets or metal profiles along the edges. This gives the furniture a little “stability boost”! 😉
The bottom panel can also be strengthened by placing a thin plywood sheet underneath, which helps distribute the load more evenly.
I think it’s definitely worth a bit of DIY fun here—the result can be impressive, without compromising the original Ikea design. 🍀
V
vinpau
11 Feb 2020 10:03
Hello everyone!
I modified my Besta cabinet by installing a wooden back panel made from a slightly thicker plywood board. This drastically improved the stability!
Now the cabinet can hold much more weight, and I can finally store heavy books and equipment. Give it a try, it’s definitely worth it! 💪📚
Don’t forget to use screws and brackets, otherwise it won’t hold up as well. Good luck to everyone!
Tobias
11 Feb 2020 10:27
Reinforce the back panel with plywood. Use brackets at the corners. Avoid overloading individual shelves. This way, Besta will last longer.
Giagau
11 Feb 2020 13:15
An effective way to increase the load capacity of Besta furniture is to reinforce the supporting elements selectively.
Simply attaching aluminum or steel angle brackets to the shelves and side panels provides additional stability. It is also recommended to replace the original shelves with a stronger wooden board (e.g., 18 mm (0.7 inches) multiplex plywood).
If possible, the back panel should not be made of a thin particle board alone but instead be a solid wooden board or a plywood-reinforced construction. This prevents wobbling and significantly increases the load-bearing capacity.
Finally, make sure the furniture is securely anchored to the wall – this ensures safety under higher loads.
PERON
11 Feb 2020 15:42
That's exactly what I did! I didn't expect such a simple stiffening to improve the load capacity so much. 😌
Additionally, you can also attach small metal brackets to the sides, as leomo already mentioned. That basically turned my Besta into a little powerhouse. 🔧💪
And the best part: you can hardly tell the box has been reinforced!
