ᐅ Can I use Ikea BESTA as a workbench in my DIY room, and if so, how?
Created on: 5 Dec 2018 09:17
HorstbauHello everyone,
I wanted to ask if any of you have experience using Ikea Besta furniture as a workbench in a workshop or DIY room.
Specifically, I am interested in whether the Besta cabinets and components are stable and strong enough to serve as a workbench base, and which worktop would be best to combine with them to create a sturdy, durable workbench.
I am also curious if the hinges, fittings, and surface finish are suitable for workshop use, and how you might protect everything against damage or dirt.
In short: Can I use Ikea Besta as a workbench in my workshop room, and if so, what would be the best way to set it up?
Thanks in advance for your tips and experiences!
Horstbau schrieb:
Can I use Ikea BESTA as a workbench in my DIY room, and if so, what is the best way to do it?Hey, I actually did exactly that myself and I’m really happy with it! The BESTA units aren’t designed for heavy industrial use, but if you reinforce them properly and put a thick, sturdy worktop on top (for example, plywood or beech), it works great! It’s important to securely screw the cabinets together and to consider a proper base—stable, level feet or a subframe.
Then, with a few protective mats on the surface, you can really get started! It’s really nice because it’s affordable and flexible! 😃
FABIAN_DEO5 Dec 2018 11:28Horstbau schrieb:
Can I use Ikea BESTA as a workbench in my DIY room, and if so, how should I best implement it?To answer your question: The BESTA series from Ikea is primarily designed for living areas, which means the load capacity and durability of the materials and fittings are intended for normal residential use. However, you can use the components in a DIY room if you keep a few things in mind.
First: The stability of the base cabinets is limited. While they are fairly sturdy, without reinforcement they may deform under heavy loads or point loads (e.g., heavier machines).
One option is to reinforce the carcasses with metal brackets or wooden battens. In doing so, make sure the weight is distributed evenly.
Second: The countertop should be robust and resistant to sharp tools, heat, and chemicals. A plywood board, a sanding board, or even a thicker beech wood board can work well. It is important that it is securely screwed to the BESTA base cabinets to prevent slipping.
Third: The hinges and fittings of BESTA are not designed for heavy-duty work. With frequent handling of heavy workpieces or vibrations, screws may loosen over time. Regular checks are therefore necessary.
I can provide more detailed advice if you tell me what type of work you plan to do and approximately how much weight you expect to store or move on the workbench.
FABIAN_DEO schrieb:
I can give you more detailed advice if you tell me what kind of work you plan to do and approximately how much weight you want to store or move on the workbench.Thanks for the detailed input!
I mainly plan to do woodworking with smaller machines like a router, jigsaw, and occasional screwing and sanding. There will also be painting tasks and minor repairs. The weight on the surface is usually under 30 kg (66 lbs) in tools, but I also have a few heavier machines I might place on it later (up to 50 kg (110 lbs)).
So the workbench should be sturdy enough to handle some heavy pushing or hammering but nothing industrial-grade. It’s just a private DIY workshop.
Horstbau schrieb:
I mainly plan to do woodworking with smaller machines like a router, jigsaw, and occasional screwing and sanding. There will also be some painting and minor repairs.For this kind of use, the BESTA is definitely suitable if you consider a few technical aspects.
1. Load Capacity: The individual modules support up to about 30 kg (66 lbs) evenly distributed. To avoid higher point loads, you should reinforce the worktop transversely with additional supports (e.g., square timber or aluminum profiles) to prevent sagging.
2. Fastening: Use screws instead of just glue or dowels to secure the connection between the carcasses and the worktop more reliably.
3. Protection: For work involving paint or solvents, it is advisable to apply a protective layer, either a removable work surface made of thick plastic or an area that has been brushed with paint or varnish.
4. Surface Hardness: For woodworking, a plywood board or coated wood surface is sufficient, which can be sanded as needed.
The thickness of the board you use also depends on the span length – at least 27 mm (1 inch) plywood or 30 mm (1¼ inches) beech is recommended.
What are the dimensions of the BESTA elements you have?
